Easy to go from 1/2" to 5/8" studs on the axles?
Silly question i guess. All you need to do is just drill and tape the axles for the 5/8" studs right? Or should i just leave in 1/2 wheel studs with my 700 HP M6 car?? Will factory 10 spoke SS wheels work with 5/8" studs?? THANKS!!
5/8" WILL fit in stock rim.
-first picture is a 5/8" stud in stock 17" trans am rim.
-second picture is stud with lug nut in stock 17" trans am rim.
-last picture is with the socket on it so you can tighten it down.
and i ordered my axles with both 1/2" and 5/8" patterns in them. so i have 1/2" in there now. an d when i go faster i can switch out to 5/8"
Internet Mechanic
Assuming this will be on a soon to be bought 9".
You will bend/break your factory studs if you actually try racing it and you maybe in the situation where you are going fast enough need longer/thicker studs.
My 12 bolt is drilled for factory, but when I upgrade I will have them modded for 5/8" They are going to be placed inbetween the factory drilled holes and just remove the 1/2" stuff.
well maybe the 16" wont. but my 17" stock CETA rims. and my bros stock 17" ws6 rims both bolt right on. so IDK
tried my brothers 16" factory camaro wheels on a 12 bolt he bought from stangeater01 on here thats has 5/8 studs, and it will not fit.... just going from experience with that. dont know about the 17 inch wheels but didnt think they were different
