Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
afr heads or 406?
Old 02-18-2010, 09:46 PM
greenturtle05's Avatar
Default afr heads or 406?
im trying to decide what i want to do. im on a tight budget and at the moment i currently have a complete l31 carb vortec engine with forged pistons and a comp xe270 cam .010 ground off the crank and heads. i want more power. so should i build the 406 or throw a set of afr's on the 350? i have a 400 block that i wanna get started on.
Old 02-18-2010, 11:03 PM
mesterious's Avatar
I say build a 406 with AFR's cause the money will be well worth it in the long run it also depends on how much power you want to make but im bias cause im building a 406 with AFR 210's with expected 550HP N/A for the street. There is no replacement for displacement.
Old 02-20-2010, 07:12 PM
old motorhead's Avatar
Cubes are good no matter what your goals are, unless your goals include serious mpg #'s. I'm building a 406 with Trick Flow 195's. I'm looking for the most power I can get with "0" drivability issues. A big cam acts smaller with big cubes. Same power, just better manners. Same thing with better flowing heads, intake, and carb. If you already have the heads, "storing" them on top of the 406 would be a good place to put them. That way, you always know where they are and you aren't apt to lose them.
Old 02-20-2010, 10:04 PM
supermouse4's Avatar
A speed shop in Moline, IL built a 383 and used the AFR 195 Street eliminator heads made over 520 hp with a mild cam.
I also like the no replacement for displacement. I say go with the 406 and build it with the AFR heads.
Old 02-20-2010, 10:09 PM
ChucksZ06's Avatar
Go with the cubes and put better heads later if you have to. My solid roller 406 makes over 500hp with Dart aluminum heads.
Old 02-20-2010, 10:11 PM
mark_H14's Avatar
+1 on the 406 With an AFR heads..
Old 02-21-2010, 11:20 AM
big hammer's Avatar
406's are mean bastards! lots of hp with a beautiful torque curve. go 406!
Old 02-21-2010, 12:00 PM
30th t/a's Avatar
I had a 408 with AFR 195s and it ran awesome. My buddy had the same set on a 430 stroker and it was wicked as hell. I say do it right and build the 406 with a set of AFR 210s and be done.
Old 02-25-2010, 10:15 PM
AutoRoc's Avatar
Well you need the heads either way.. heads make power.. Vortecs on a 355 or 406 will be a bottleneck either way... heads make power.. There is a replacement for cubes... it's rpm..
Heads...more cam/rpm... A 355 with the new 235's might sound like overkill but it will scream with the right cam. On the 406, I'd do nothing less than the 235 Eliminators.. Not hard to make 700hp with these new heads.
Old 02-27-2010, 11:07 AM
68lemans's Avatar
put some pro/filers / air wolf 220s on it an call it a day.s
Old 03-07-2010, 12:57 PM
Zfan's Avatar
What intake would you guys suggest running on the 210 heads? I have a 385 sbc with 210's and a unported Victor Jr. I have heard the Victor Jr. is to restrictive and to run a Super Victor.
By the way, go with the 406 and AFR 210-235's, either way they will rock.
Old 03-07-2010, 01:34 PM
Depending on your application, for the street performer rpm air gap.
I'd consider super victor port matched for racing.
Old 03-21-2010, 10:56 AM
about how much hp/tq can i expect if i put the afr on the 350. thanks for all the response guys.
Old 03-26-2010, 05:06 PM
Razor's Avatar
The Vortec's flow pretty well for a stock GM head. I would rebuild the 400 and get the Vortec's drilled for steam holes. Use these heads until $ permits the purchase of a set of AFR's. Super Chevy or one of those magazines did a build up on a 406 using Vortec's and it made something like 470 hp and 500 tq.
Give AFR a call once you get close...excellent customer service and they will steer you to the right choice for your application.
Quick Reply: afr heads or 406?
