carbed mustang people!!!! or fuel injected
what size cowl hood are you having to run to clear the carb hat?
fuel injected guys how much room is there from the top of your intake to the hood?
thanks
thanks
can some one please give me a measurement from the top of the intake to there hood? I'm going to be running a 6.0 with a vic jr intake and a carb but my air hat has a 2" spacer on it and i need to know if a 4" cowl will clear it. i found a good deal but I'm not sure if it will clear.
from the intake manifold/carb mounting surface i need 9.5" minimum.
please can some one get me a measurement
Im running a truck intake on mine and it clears a 2.5" cowl hood. With a 4" hood it should work as the only place im even close is at the front where the throttle body is and I got it to clear with the cover on the intake.
I don't have the car with me to measure, but here are a few reference pics. This is using a L92 Vic jr. and a 1" spacer. Its VERY close with a 4" hood ! Even with a drop base 14"x3" filter .
