View Poll Results: oil pan?
lhx
3
25.00%
autokraft
6
50.00%
cts-v
3
25.00%
Voters: 12. You may not vote on this poll
chevelle oil pan?
Old 03-07-2010, 01:22 PM
rallystyle's Avatar
Default chevelle oil pan?
ok i am putting a ls1 and a t56 in a 69 elcamino. i need to decide what oil pan to use. i like the looks of the lhx and the autokraft pans. and theres the cts-v pan. the car will be low so i need ground clearance and the roads suck up here (AK). i will do some auto-x with the car so oil control is a big problem also.
on a side note are there any fuel rails that are passanger side feed that fit the ls1?
Thanks
Old 03-08-2010, 12:01 AM
lamdenali's Avatar
I use Mod F-Body pan from S&P
Old 03-08-2010, 12:15 AM
wade70ss's Avatar
Default Chevelle Oil Pan
I'm looking to use the Autokraft pan. I have a 70 Chevelle w/T56 and am worried about the ground clearance as well. The only issue with the S&P pans is you must have a core of the pan you're purchasing. Otherwise you have to pay a rather expensive core charge.
As for the fuel rails I just ordered some rear exit fuel lines for my 5.3L from S&P. They make them to use the factory GM connector and run them to the passenger side frame. UNFORTUNATELY I ordered them and a few other parts from S&P at least 2 weeks ago and haven't been charged or received anything yet. I'll be calling tomorrow to get an update.
Old 03-09-2010, 01:08 AM
Rushforth's Avatar
I just received my AutoKraft pan and it's a very nice piece that is made specifically for our old cars so it's a no-brainer.
Old 03-09-2010, 08:12 AM
rockytopper's Avatar
I also used the S&P modified pan. The only autocraft pan I have seen installed on an abody is B-mans 64 pony. His steering knuckles hit the front corners of the pan. That is my main concern with all of the after market pans I have seen for the A-bodies. The front is thicker than the F-body pan and the front corners are not dimpled to clear the steering knuckles like the f-body pan has. In my case the pan sits about 1.5 inches off the cross frame and the steering links darn near hit the pan. The dimples are all that allow clearance at full lock.
Old 03-09-2010, 08:39 AM
Forcfed93's Avatar
I have a 71 El Camino and I used the Autokraft pan. It's really close to hitting the steering knuckles, but it clears.
Old 03-09-2010, 08:47 AM
john 67's Avatar
I also used the modified f body from S&P, I also used a girdle fitting to hold the pickup tube in with 2 bolts instead of 1 ( by the oil pump ).did you look at the Canton pan ? looks to have good clearence up front ,you can flip the fuel rails . JOHN
Old 03-09-2010, 02:20 PM
bczee's Avatar
I am using an CTS-V for the past 4+ years.. if I was going to do it again and wanted to keep a cast pan, I would use the LHx, which I now have one for my 71 Nova that I am doing the swap on soon. If I was concerned about weight, I would then use the Autokraft. I did voite Autokraft for you, as you said you were going to be Autocrossing with it. The LHx pan states that they don't recommend racing with there pan. I have had no problem with running at the Good Guys autocross events with the CTS-V pan.
As far as the fuel railing feeding from the right side. just flip the rail 180 deg.. I have done this and no problems.
Check my Cardomain project by following the link in my sig.
Good luck and keep them posts coming.
Old 03-10-2010, 04:49 PM
rallystyle's Avatar
bczee i have been reading your site. lots off good stuff on there. i also went through stealth71 post. i would put up some pics but the car is in a snowbank right now. i thought there was some one that had there autokraft pan moded for the steering linkage and it was ordered that way from autokraft. any one have pics of there pan on the car? also i am going to use edelbrock engine mounts if that helps. thanks
Old 03-10-2010, 10:48 PM
71 chevelle's Avatar
I am using a ctsv so far no issues but the body is off the frame.
Old 03-11-2010, 04:53 PM
bczee's Avatar
Yeah.. me and Stealth started work about the same time and shared much information together on the two builds..
I did vote Autokraft because of what you said you were going to do. you have to weight out what your requirement are before you get your answer.. there is alway many way to get the point you need. But some are just better suited once you have your requirement and goals up front.
If you have any question .. go ahead and ask them.. more than glad to help out.. keep th post coming..
BC
Old 03-11-2010, 09:45 PM
here is a pic of the ctsv pan.
Old 03-12-2010, 08:11 PM
1969x11's Avatar
I'm in the process of swapping a lq9-4l60e into a 69 Lemans and i did a self modified F body pan. If you know someone who can tig I would check into it.
Old 03-13-2010, 10:10 PM
Gary U's Avatar
I used the Kevco Pan as I was concerned with tie rod clearance on the Autokraft. Engine sits low using Edelbrock plates, but no interference with the tie rods. Also, the pan is higher than the crossmember so no ground clearance issues. Only down side is a remote filter must be used and I had no idea what a pain in the *** that would be, not to mention the extra cost of hose and fittings.
Not driving yet, but hopefully in the next couple weeks.
Old 03-14-2010, 11:10 AM
Turbo Dan-O's Avatar
I can't beleive this is not in this thread: http://jzmotorworks.com/LS1Pan.html For me this is the only way to go.
Dan-o
Old 03-15-2010, 10:31 AM
bczee's Avatar
That is the pan that RetroLSx markets.. I have one for my Nova Swap that I am about to start. in post #8 I talked about it.
Old 03-18-2010, 10:25 PM
clm69z28's Avatar
I used the Autokraft pan and Edelbrock motor mounts in my '72 Chevelle 'vert. I shimmed the motor about 1/2" on the drivers side and 3/8" on the pass side (some probably related to frame sag) and there is no steering conflict. The pan clearance is good; it doesn't hang below the pan.
Attached Thumbnails chevelle oil pan?-p1010247.jpg   chevelle oil pan?-p1010248.jpg   chevelle oil pan?-p1010365.jpg   chevelle oil pan?-p1010366.jpg
Old 03-19-2010, 08:54 PM
rallystyle's Avatar
thanks for the pics clm69z28 thats what i was looking for. i will go with the autokraft / champ pan for mine. you should post he pics in the sticky because i know alot of people ask about the pans.
Old 03-19-2010, 11:03 PM
jmstmoose's Avatar
Here is the pan I used from SommersRacing
Old 03-20-2010, 04:32 PM
93Polo's Avatar
Dan-o
Does the pan have any baffling for oil control? Autokraft/Sommers has trap doors for oil control under cornering.
Quick Reply: chevelle oil pan?
