How much is a used UUC shifter/bushing worth?
Plus the shifter bushing. Like mentioned above, resale parts for the V's is higher than any other previous car i've ever owned. I guess you could chalk it up to the lack of used aftermarket parts for sale at any given time. How many used shifters do you think are on the market right now for a '03 Cobra, or '92 GT?
CTS-V Shifter Sales
maxpennmatt modifies them the same way I do, he came up with the original idea. If you're going to modify a stock one, that's the way to go. If your's is still a little sloppy side-to-side when in gear after the modification, PM me and I can send you some new nylon bushings for the base of your shifter. I've redesigned them a little larger and had some made. They may be worn and cause this.
How much for the bushings? Im going to order a UUC bushing... will i still need those?
