clutch noises, is it the TO bearing?
Old 03-17-2010, 12:20 AM
slvr98camaro's Avatar
Default clutch noises, is it the TO bearing?
hey guys, i made a thread a while ago about having clutch noises, and after playing around with it, i have new info..
When i press the pedal down, everything is fine for about 3 seconds, then i start hearing a rubbing/rattling noise coming from the clutch area. I have no problems and no grinding when trying to go into reverse, or 1st gear, it goes in very smooth
I also hear the noise when i am driving and press the clutch in to downshift, or when i upshift at a low rpm
I blead the hydraulics using a mityvac in the slave resivour, and it seemed to make the problem worse, but my pedal felt really nice and firm, unlike it did before.
After i drove the car for about an hour, and pulled in my driveway, i noticed that when i pressed the clutch in it didnt make the noise nearly as bad, but still made it
do you guys think that the TO bearing/slave is bad? Its the only thing i can think of, other than the pilot bushing being worn (the pilot bushing, clutch, and TO bearing/slave were all replaced a year and a half ago, and have approx 15,000 miles on them) If it matters, my transmission has a small leak somewhere, when i checked the fluid i was a quart low, and i saw fluid on the side of the transmission where the speedo sensor was
any other suggestions? Im thinking of dropping my transmission tomorrow, but i would like some suggestions first in case it may be my master cylinder, or something else.
thanks for any help
Old 03-29-2010, 05:49 PM
IanWatson's Avatar
Bump for you because I have the same problem minus the leak.
Old 03-29-2010, 06:48 PM
1904gto's Avatar
is there a vibration in the pedal?
Old 03-29-2010, 07:15 PM
IanWatson's Avatar
For me I have a slight vibration in both the clutch pedal when engaged and when I am idling while on the brake. Also when idling I can hear a noise coming from the shifter itself. It's like a very quiet grinding noise, but goes away when I put it in gear.
Old 03-29-2010, 07:24 PM
killagt's Avatar
Try to adjust the cable, and the noise is properly worm out TOB.
Old 03-29-2010, 07:34 PM
bigj2717's Avatar
There is no cable to adj the clutch is hydralic
Old 03-29-2010, 07:56 PM
killagt's Avatar
good that one less thing dont have to replace
Old 03-29-2010, 10:10 PM
IanWatson's Avatar
Would this also be the reason when the clutch is engaged and I'm in a gear, I get a rubbing noise and vibration when I am between 1350-1600rpm?
Is a throwout bearing difficult to change? I haven't worked on a transmission before, so should I take it to a shop? If so how much would that cost? And how much would a new slave cylinder cost to put in? Estimates anyone?
Old 03-30-2010, 08:46 AM
01ssreda4's Avatar
I have seen pilot bearings act similiar.
Old 04-01-2010, 07:11 PM
nascarnate326's Avatar
Mine does the same thing. Its not too bad but I do want to get it fixed some time.
Old 04-01-2010, 10:50 PM
1904gto's Avatar
my pilot bearing blew out and everytime i engaged the clutch well almost everytime i would get a slight vibration in the pedal
it was throwing the inputshaft off line and fucked it up
i say check it real soon cuz my input shaft was like 450 and thats employee pricing
Old 04-02-2010, 07:18 PM
IanWatson's Avatar
How much would it cost do you guys think to get a throwout bearing and pilot bearing replaced? And is it possible to do it yourself?
Old 04-02-2010, 10:02 PM
1904gto's Avatar
pilot bearing is like 12 bucks or smthing throwout bearing comes with the slave and i think f body ones are round 90 bucks
and you could do it yourself if youve ever dropped a tranny before
ive only dropped 5.0 fox body trannys before and i would feel comfort doing that on an fbody
thats just me tho
Old 04-03-2010, 12:24 AM
IanWatson's Avatar
thats just me tho
Any reccomendations on where or what to get? Would I be ok just getting an ACDelco slave cylinder and pilot bearing form rockauto? Or should I go for something else? And I've never dropped a trans before, but hey you gotta start somewhere. I would just need to buy a tranny jack...
Old 04-03-2010, 04:23 PM
1904gto's Avatar
yeah acdelco cool id just get OEM equip
