Drag Racing Tech
339rwhp and 1/4 time
Old 01-01-2004, 11:12 AM
98SS Blackattack's Avatar
Default 339rwhp and 1/4 time
Dynod 339hp and 335Tq, Just want to get some input on what to expect. Have all free mods plus whats in my sig.. No headers etc. If i cut 1.7 60fts what 1/4 could i expect?? I know my #'s are not that good for a cam car but. High stall+no ls6intake+no headers+no pulley+no tunning i think they are good.Shift points are set at 6400rpm.
Old 01-01-2004, 11:35 AM
red fury's Avatar
with 311rwhp and 320tq in my M6 I ran a 12.69 on a 2.00 60'
Old 01-01-2004, 11:36 AM
JoelSS's Avatar
First of all, I think you could do at least a 1.6 60' assuming you have good tires. With that in mind, I think you should be somewhwere in the 12.1-12.2 range given decent track conditions (traction, DA, etc.). My 6 speed car did a 12.1 with a 1.70 60' time and it has 342hp and 354 on torque. I would say you should be right there with your automatic.
Joel
Old 01-01-2004, 12:54 PM
big dave's Avatar
It should get you into the low 12s. If you could possibly get into the 1.6s you could even see some high 11s. My 94 lt1 made 345 rwhp and ran 12.01 @ 113.5 with a 1.67 60'. Raceweight was between 3650 and 3690.
Old 01-03-2004, 02:55 AM
kcsoz20's Avatar
I agree with all the above. The times in my sig were run with 330 rwhp. I have dyno tuned it now that is why you see 365 in sig.
Especially with you running a 3500 stall I think you should easily be low 12's maybe even an 11.xx.
Ken
Old 01-03-2004, 07:22 AM
Charles Cyrus's Avatar
I dynod 330hp and 346tp. Car is 01 M6 WS6 no cam no heads no headers, mini LS1edit, car weight is 3520. It ran 1.77 60ft-7.83@89.51 in the 1/8-12.18@112.95 in the 1/4, thats with 4:10 gear and 315/35/17 Nittos.
Old 01-04-2004, 08:39 PM
Gamble's Avatar
This past weekend I went to the track and couldn't get under a 2.0 60'. My best pass was a 12.8 @ 111. I think I should have been running maybe a 12.5 with a 1.8 60'. Do you think I might be able to get a 11.99 with a 4:10 gear, a good tune, and better traction?
Old 01-09-2004, 09:25 PM
Blown Ta's Avatar
my car dynoed 339 hp my best 1/4 was 13.1 on stock tires
mods in sig
Old 01-09-2004, 11:32 PM
I dropped 2-10s by going from 3.42s to 4.10s.With LS1edit and a low 1.70 60ft, it would be close. Good luck!
Old 01-13-2004, 12:14 AM
camarolt1's Avatar
My 94 lt1 A4 weighs in at 3650 also.
I put down 280 rwhp.
I had a 1.87 60' with 17psi Nitto Drags and ran a best of 13.54 @ 101.8...
Is my car broken??? Why does your car trap 12 mph higher with only 65 more groundpound? Shouldn't I be trapping at 105+ ?
Thanks Dave
Old 01-13-2004, 01:44 AM
PunkNPonys's Avatar
You will be somewhere in the 12s for sure. I ran 12s with the same things you have minus the cam.
Old 01-13-2004, 02:10 AM
Gamble's Avatar
I would think under 12.5. I'm sure you'll be able to tell where your at by your MPH, but your ET will all depend on the first 60'. I was trapping at 112, which proved that my HP was there but my 60' were not. I learned that's where it's all at man... Those first 60' of the race. Good luck.
Old 01-13-2004, 10:46 AM
big dave's Avatar
I wouldn't say your car is broken. Alot depends on the weather conditions as well as altitude of the track. My quickest passes were made in ideal conditions,(45-50 degrees)at an almost sea level track. My mph would fluctuate anywhere from 109 in the summer to that 113.78 which was achieved at 2 different tracks, in good weather. When I was making 271 rwhp with just boltons, I would trap anywhere from 101 in the heat, to 104 in good air.
