Notices
WTB: stock parts
Old 03-20-2010, 06:30 PM
1A Dan's Avatar
Default WTB: stock parts
hey guys, in need of a few parts here for my LSx swap
-LS1 flexplate to crank bolts. need all 6
-fbody water pump. used is fine. looking to keep it under $50
-gaskets. everything needed to swap an oil pan, timing chain, and oil pump
Thanks guys!
Old 03-20-2010, 06:33 PM
1A Dan's Avatar
almost forgot the MAF. could use one of those too!
Old 03-20-2010, 06:58 PM
ddr698's Avatar
I have an LS1 oil pump with 10k on it.... $40 to you. (not sure if you are looking for a water pump or oil pump).
Old 03-20-2010, 10:16 PM
superssport's Avatar
pm me exactly what you need. I should have everything.
Old 03-21-2010, 07:09 AM
Boost-box's Avatar
I got the bolts I'll send you for free if you cover shipping of $5
Old 03-21-2010, 11:32 AM
1A Dan's Avatar
already have the oil pump, just need the goodies to swap one! thanks for the reply though
Old 03-26-2010, 04:21 PM
1A Dan's Avatar
got a water pump, all set here!
now in need of LS1/6 intake manifold bolts
still apparently need flexplate bolts (the short length, not the ones for the crank spacer)
Old 03-27-2010, 04:51 AM
DiabloFormula's Avatar
I have a set of intake bolts and I might even be able to get some flexplate bolts for you as well, PM me an offer on the intake bolts and I will get back to you on the flexplate bolts.
Old 03-27-2010, 10:35 AM
1A Dan's Avatar
you've been pm'd!
