traction and new gears
Old 01-02-2004, 12:58 PM
ducati916's Avatar
Default traction and new gears
Im thinking about upgrading to 3.73 or 4.10/4.11. Will I smoke the tires any easier? Are these gears hell on the highway at traveling 65 or so?
Old 01-02-2004, 09:22 PM
mike c.'s Avatar
i've had both 3.73's and now 4.11's w12bolt. the 3.73's are good and at 80mph i was on 1,900rpm's. the 4.11's are great with the m6 and at 70mph i'm on 1,800rpm's or so. with the 3.73's traction won't get much worse,but the 4.11's will fry the tires. the 4.11's will make the car feel 200lbs lighter. the 3.73's would be my choice if i did'nt have the $$$$ for a 12bolt. good luck to ya.
Old 01-03-2004, 09:09 AM
LS1Tech Sponsor
Slowhawk's Avatar
M6 cars should of came with 4.11's from the factory.They work great for the highway when I cruise at 90mph..
Yes,you will lose traction with them easier at lower speeds.
Old 01-03-2004, 09:57 AM
z98
z98's Avatar
But you'll be able to launch easier.
And you could run 5.13 gears at 65 mph and not even notice.
Old 01-03-2004, 10:19 AM
WARNING: BAD TRADER STATUS
TWISTA TA's Avatar
Slowhawk what rpm do you turn at 65mph with your 4.11's
Old 01-03-2004, 05:23 PM
mcflyz28's Avatar
On street tires I haven't gone wot in 1st gear since my tune instant spin at any RPM, second gear is a little better but not much in stop light wars it's a bitch, now drag radials whole different story !!
Old 01-03-2004, 10:47 PM
ducati916's Avatar
i have a th 350 what would rpm be like with 4.10 or 4.11 at 90 mph
Old 01-03-2004, 11:43 PM
itchygomey98's Avatar
That's going to depend on tire size. Assuming that your tires have 25.65 inches diameter (245/50/16's), here is the math -
tire circumference in feet = (25.65 * 3.14)/12 = 6.71 ft
rpm = (mph * final gear ratio * 88) / circumference in feet
rpm = (90 * 4.11 * 88) / 6.71 = 4851 rpm's
You'd be just under 5 grand at 90.
Now don't forget - 3rd gear in a th350 is 1:1, so you just enter in the rear gears as the final gear ratio. In an overdrive tranny, you'd have to know the last gear in the tranny (.73:1 for an example). Then final gear is .73 * rear end gear.
Old 01-04-2004, 12:06 AM
ducati916's Avatar
sweet thanks
