Help 68 mustang 6.0 swap
Old 03-23-2010, 06:47 AM
jconde's Avatar
Default Help 68 mustang 6.0 swap
Guy's i need help trying to fing out if anyone sell's universal motor mount kit that will help me drop this motor in also i want to run efi does anyone know how i can get a wiring harness that would just run the motor thanks jeb conde houston texas
1968 mustang
lq4
l92
ls hot cam
Old 03-23-2010, 01:21 PM
BlackTA96's Avatar
Search search search search search Search search search search search Search search search search search Search search search search search Search search search search search Search search search search search Search search search search search Search search search search search
Old 03-23-2010, 03:44 PM
Roar's Avatar
No to motor mounts, yes to wiring harness....and oh, uh... Search!
Old 03-23-2010, 04:05 PM
nick1ta's Avatar
lol google would probably land him back here!
Old 03-23-2010, 05:05 PM
bmxmon's Avatar
Damn huh?
Old 03-25-2010, 08:52 AM
jason dearduff's Avatar
i have done that. check the archives there are pics in there, or contact me at jasondearduff@hotmail.com.
Old 03-25-2010, 12:08 PM
crosstraining's Avatar
Most of us know how to search, but who wants to slog through the thousands of posts to get a couple of simple answers. If you know the answer then help the guy out. Thanks to the guy who gave his email and actualy offered to help. I hope someone gives you some straight answers because I would love to do a similar swap in the future. Good luck
Old 03-26-2010, 12:48 PM
ok a few hints, you need a gto oil pan. i used progressive engineering motor mount, had sanderson build me custom headers. and used speartech for electronics. hope that helps? i can't post pics but if you give me your e-mail i can send them to you. as far as i know i am the only one with a operating driving example of this conversion and i am willing to help whoever needs it.
Old 10-20-2010, 09:40 AM
Posi12Bolt's Avatar
it does... i've tried as I'm gathering parts for my cougar/lsx build
Jason, I will be contacting you.
that is absolutely the most informative post on the entire internet about putting an LSx into a classic mustang or cougar... and I'm serious!
Old 03-12-2011, 07:38 PM
jseely's Avatar
I am putting a ls1 in my 67. I used dirty dingo mounts. My exhaust is my only major problem left. I custom built frame connectors. Relocated the firewall back about 3 in. Im using the cts-v front brackets. You can see some pics on fb seely's automotive. I will put some updated pics up when i get time. A 94 jimmy driveshaft fits perfect.
Old 04-04-2011, 11:22 PM
turbofreek's Avatar
So does these dirty dingo mounts bolt right up? I'm wanting to buy a 68 stang and add a 5.3 with a turbo to it. I want it to be a bolt In deal though and cheap. It's just a ragged toy for Sunday fun.
Old 04-05-2011, 01:55 AM
Irish350's Avatar
sounds like they made his swap easier, but he moved his firewall back 3", id imagine he didnt leave that for a gap behind the engine, and that doesnt sound like an easy bolt in deal unfortunately..
i still havent seen any known to fit/specific mounts for these older fords
Old 08-04-2011, 07:38 PM
jseely's Avatar
Dirty dingo is a universal hot rod style mount welded in with no problem. I Relocated the firewall so it would be flat. My A/c and heater lines will all be hidden in the fenders. I done the firewall for looks only didnt like the looks of it. Have my headers built, as soon as i get the underhood painted i can hook everything up.
Attached Thumbnails Help 68 mustang 6.0 swap-270613_248369148512132_138407786174936_1195036_6819483_s.jpg   Help 68 mustang 6.0 swap-261383_248374168511630_138407786174936_1195107_6782461_s.jpg   Help 68 mustang 6.0 swap-264267_248374548511592_138407786174936_1195121_5343379_n.jpg   Help 68 mustang 6.0 swap-47851_157206887628359_138407786174936_534181_4947817_n.jpg
Old 09-21-2011, 05:36 PM
97C5driver's Avatar
jseely, any more pics of your install?
Im starting to collect parts for this swap in my 67 fastback.
Old 09-29-2011, 05:46 PM
wesmigletz's Avatar
Glad I found this thread. Haven't had much luck with a search. I might be taking a '69 Mustang as a partial trade for my Chevelle, and am considering a LSx swap. I already have the GTO pan/pick-up, but not much else.
Old 01-07-2012, 09:01 PM
boogiewonderland's Avatar
can you send or post some pics im interested in seeing the mounts.
Old 06-12-2016, 05:58 PM
kenneth whitmore's Avatar
The swap is not complex at all. I put a LS 1 six speed in my 1969 Mustang fastback and it runs strong. Will post pictures and I am not worried what the ford guys think because this is my car and money. It get twenty miles to the gallon, plenty of power and most importantly I can drive it any where without worries of if it is going to break down.if you need help I will give you all the information that I have.
Old 06-13-2016, 02:18 AM
mmag0428's Avatar
Default Mounts etc...
Mine is a 66 that i swapped. Made my own mounts. Also moded a set of fbody headers. I have since changed the to hooker swap manifolds. Fit was perfect. If i can help my email is mmag0428@Hotmail.com
Old 10-03-2016, 10:16 PM
1965 ls2 GTO's Avatar
I am wanting to swap a 6.0 into a 1966 Ranchero. was there any modification to the tunnel needed for the 4l60?
Old 10-04-2016, 09:13 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
I fit a T56 in my 67 Cougar without tunnel modifications. The trick is to move the engine forward slightly.
Andrew
Quick Reply: Help 68 mustang 6.0 swap
