Anyone ever put different seats in a F body?
You need to search for this one. There have been many threads with different seats from Corvette seats to GTO seats to aftermarket leather seats or racing seats. There is a vendor (6LiterEater) that sells a few different seats for our cars as well.
The rear seats should be a direct swap between a trans am and a camaro. i've removed my T/A seats before and there are is 1 bolt (13mm i believe) on each lower seat pad and then 1 bolt on each side of the lower part of the upper rear seat and then 2 T30 torx bits on each side for the seatbelt holder. i'm 99.9% sure upper and lower seats for a trans am are a direct bolt in for a camaro and vice versa. only the upholstery and foam padding are different. the seat frame should be the same.
There aren't many late model cars that have a bench seat like fbodies.
Why not get the rear seats covered in material similar to front (after market, or retro fit seats you are getting)?
I remember seeing a convertible T/A that had racing seats meant for the front, but custom fitted in the back. I 'll try to find the picture.
