68 camaro 6.0 question
Just finished the swap on camaro, carbed 6.0.
It idles fine but when you hold the throttle at a higher rpm it starts surging and sometimes pops out the exhaust? I don't know if I have a bad coil pack or I'm not getting enough voltage? Has anyone experienced this? I'm just burned out mentally.
Thanks
Thanks
Mine did the same thing. Make sure your power wire is from a switched 12 v source. When I first wired mine up it was pulling power from a 6 v wire, so anything over like 3 grand it broke up and back fired.
