Car Storage Problem
Car Storage Problem
Well winter is around the corner and I will be storing the TA. Unfortunately I do not have a garage so its going to be kept outside under a good car cover. My big problem is that it will have to sit on grass for the months that its put away. I was told all the water in the ground will cause havok on the underside of my car since it snows so much around here. Is this true? If so, what can I put on the ground to stop anything bad from occuring?
Re: Car Storage Problem
I would park the four tires onto thick rubber mats so that the tires are not sitting directly on the moist grass. Better yet four concrete pads like what airconditioners are set on and then the rubber mats. The moisture under the car will be about the same whether it is on a hard surface or not.
Copy & Paste Moderator
You can always get a set of winter rims with Blizzak tires from TireRack and drive it in the winter. This is what I do, since I have only one car and need to drive an hour each way to and from work.
As for storing your car, there is a product called "Car Mat" or something like that. Its meant for garage floors, but could probably be used outside too. There is always an ad for it in the back of either Car and Driver, Road and Track, or MotorTrend. There may also be an ad in HotRod or CarCraft.
--VIP
--VIP
