oil pressure sending unit
Old 03-27-2010, 07:47 PM
f-body_racer99's Avatar
Default oil pressure sending unit
Well I was takeing out my stock LS1 intake and happen to have broke my oil pressure sending unit and was wondering where I can find one I've looked in many places but noone carrys them. Also how do I take it off?
Old 03-27-2010, 08:21 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
LS1 oil pressure sending unit (sensor) (99-02) = 12562267
Some parts stores also have the socket needed to remove it
Old 03-28-2010, 04:04 PM
Thanks and is the socket to take the old sensor 27mm
Old 03-28-2010, 06:49 PM
transambroli's Avatar
Got my sending unit from autozone. For the socket if you have a 1-1/16" deep socket laying around that might work. Or you can buy an oil pressure sending unit socket for gm vehicles, I got mine from NAPA.
Old 03-28-2010, 07:49 PM
greasemonkeysoldier's Avatar
lol, i did the very same thing today....swapping my LS1 for a LS6 intake....broke the sending unit...i went to Autozone and they had to order one because they didn't have one in stock. Bought the Sending Unit socket while i was there too. All it is is a 1- 1/16th deepwell socket...nothing special.
Old 03-28-2010, 08:46 PM
How are you liking that LS6 intake any differences?
Old 03-28-2010, 08:59 PM
94Z28-MSTGKLR's Avatar
I don't mean to hijack your thread but, I think mine may be messed up. Can you replace these with the intake still on?
Old 03-28-2010, 09:18 PM
Its ok man. and I think it would be alot harder with it on then off.
Old 03-29-2010, 02:10 PM
02v8ta's Avatar
i need to know the same thing... lol, any advice or tips would be appreciated.
Old 03-29-2010, 04:39 PM
lol, I haven't even gotten the intake full yinstalled yet. I'm waiting for my oil sending unit to come in tomorrow to finish. I'll let you you how it runs once its done though.
From what I can tell with the intake out right now it is possible to do with the intake still in it but would be a big PITA and take LOTS of patience. I would suggest taking the intake partially out as in leaving the fuel rails attached and just sliding the intake forward a bit to get at sending unit better....should be pretty easy to get at from the passenger side with the intake moved forward. But if you left it in I would think the best way to get at it would be from the driver's side. but like I said it would be PITA that way.
Old 04-18-2010, 07:51 PM
skopers3's Avatar
I just did this today and it's a LOT easier than the hastle of taking the whole intake off. I just reached back there, disconnected the wires, Slid the socket back and dropped it into place, slid an extention back there on top of the socket, then wrench on top.
it was actually pretty easy.
Old 04-19-2010, 12:54 PM
PERFECT Z28's Avatar
I remember when I did my camp swap, went to crank it for the 1st time and no OIL PRESSURE ut everything sounded fine...I broke the sending unit when I swapped out the old intake...lol
Quick Reply: oil pressure sending unit
