6 speed guys with MSD 2 step
Yeah i forgot what wire it was but its on the 4 pin connector. and yes everytime you depress the pedal the light should come on the msd box, and when you set the 2 step at desired rpm and floor it it studders. again cant remember think it was the Ground side of the msd box.
Excellent, thanks for that! Is this how you have yours and it works? So I need to tap into the purple/white wire and not the dark green wire? I'm looking at a wiring diagram of that circuit right now and it shows switched 12v coming into the purple/white wire and when the clutch switch closes it sends 12v through the dark green wire which powers the starter relay.....so according to the diagram that switch only gets 12v during start conditions?.....
It doesn't......but think about it, when are you ever going to rev the car up to say 5-6K unless you plan on launching, if you don't plan on racing one day or just driving around the town, all you have to do is set the MSd to like 8K, which you'll never rev to anyways.
I tried tapping into both wires coming out of the clutch safety switch and it just wouldn't work. Ended up just removing those wires from the safety switch and splicing them together (car starts without clutch pedal pressed now). Then I ran a switched 12v source and the 2 step activation wire to the old safety switch on the clutch pedal. Works good!
Hey Mike, Where did you buy that coiled wire? I'm putting in a 2 step the same way you are, but with a sparco steering wheel with a sparco horn button. Just need the coiled wire.
I wired mine in to my factory fog light switch. So I turn on my fog lights to arm it and then the hot wire on my brake lights is the activation. works GREAT! my car is an auto car but it would work on either application
