Cadillac CTS-V - '05 V - feels like warped rotors - but all new brakes!
DoesSpeedTurnUon
04-02-2010, 05:29 PM
This started as what I thought were warped brake rotors. When I hit the brakes, the steeringwheel would start to shake like they were warped. I had new brakes put on. All GM parts, new rotors and pads. Problem is still there. Anyone have any clue?!
the only thing i can think of is tie rods or ball joints. But even then, something has to be making it shake?!
1bad2k
04-02-2010, 05:40 PM
Have you had your front tires checked for balance? Are both fron wheels true and straight? Its not unheard of to get brand new rotors that need a very slight cut (turn)
tityrous
04-02-2010, 05:41 PM
are you calipers freezing up at all? Try lubing them and check your wheel bearings also!
keith
DoesSpeedTurnUon
04-02-2010, 06:25 PM
calipers i dont think are freezing and i have changed front tires as well and its still there.
itsslow98
04-03-2010, 12:02 AM
keith
i the calipers were freezing youd be getting a slight pull to one side. Had that problem on my jeep.
tityrous
04-03-2010, 07:55 AM
Not all the time if both sides are freezing up it will pulsate pretty bad but you would smell the brakes and your rotors would be very hot. some vehicles are different this happened to my parents old Mirage...
Driven2slow
04-03-2010, 10:32 AM
I think you rotors need to be turned. Go easy when braking, dont slam on the brakes everytime.
punishmentcycle
04-04-2010, 09:32 AM
tierod end is my guess.. if they are new rotors and ur problem is still there i highly doubt brembo rotors are out of wack. best way to check is to put the front wheels on a turn table and check for play
ya rotors defintely need turned, I have seen warped rotoes right off the shelf from the partshouse
DoesSpeedTurnUon
04-04-2010, 01:23 PM
damn, if it wasn't easter sunday, i'd have them done today!
TomJoeC88
04-04-2010, 01:51 PM
Instead of guessing just jack up the front end and set it on jackstands on the fr a-arms. With the ball joints loaded like that u can just grab the fr tires and see if they wiggle cuz they shouldn't. But the rotors technically could get warped by zapping the tires on with an impact too tightly. Make sure to not get em too tight just 100ft lbs with a tq wrench.
thebigjimsho
04-04-2010, 01:57 PM
Did you bed the brake pads? I would try that first...
DoesSpeedTurnUon
04-04-2010, 08:15 PM
I did that yesterday and there was no movement. Which made me think more about the rotors.
What's "bedding" a brake pad?
UPDATE****
I rushed home after easter today - pulled the rotors off, had them turned. The auto parts store said "they were warped but not enough to fix what you're describing" Well I'm hoping they were wrong cause my shimmy is GONE! Not sure if its gone temporarily or i haven't got them hot enough again yet but its certainly not there. Only problem now is they don't seem as grabby but i'm sure they'll be back to normal in no time.
CancerJCC
04-04-2010, 09:04 PM
You are kinda answering your own question. You are bedding in some of the brake pad material on the rotor. This would explain why after they turned them they aren't as grabby.
Google it.
JJSimon904
04-04-2010, 10:43 PM
I have a similar issue, but its only when I get on the brakes for the first time at speed...after that it doesnt shimmy for the rest of whatever trip im doing. Mine are probbly due to be turned.
CancerJCC
04-04-2010, 10:49 PM
FYI the V rotors usually cannot be turned due to lack of thickness out of the box. Don't have the specs for you but I do know this is the case.
JJSimon904
04-04-2010, 10:53 PM
good info..thanks
thebigjimsho
04-05-2010, 09:49 AM
UPDATE****
You may have had them turned for nothing. Or maybe not. Bedding brakes is getting pad material onto the rotor.
http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85
Now, as for getting your rotors turned, that's usually a no-no because our rotors are not generally thick enough to safely turn. However, since they were new ad only would need to be turned a small amount, you should be OK. But your rotors life will be a little less...
Z06phile
04-05-2010, 07:21 PM
I just fixed the same problem you're describing. I took the front rotors to be turned, but they were too thin already. Bought new ones from O'Reillys for $68 ea. The shimmy is gone. No bedding in or anything special.
1bad2k
04-05-2010, 07:41 PM
bedding in isnt anything special really anyways, but it should be done with every new set of pads/rotors installed.
