Knock Sensor
Knock Sensor
Just got my Camaro SS back to day from getting my LS1 rebuilt...driving around tonight i got a P0327 knock sensor 1 low circuit imput...is this because im using 93 octane? are they bad? or is it because i have a small exhaust leak and its picking it up as a knock? the link will be fixed because im getting my SLP LM1 put on. Any help would be great!!
Thanks guys!
Thanks guys!
I had both of my knock sensors **** out on me. Its probably due to them being old and needing replaced. I drove on mine f***ed up for over 6 months and never noticed a differnece. Have fun replacing them. If you do one then do them both cuz the manifold has to come off.
wouldnt be a bad idea to have the harness for them also. I just changed mine and cracked both connectors during removal. They are hard to reach and crack easy from the heat. its like a 50 dollar part from the dealer
I was going to mention a harness since I messed mine up trying to remove it and had to replace it (same as you, the connectors), but I thought maybe I was just careless. Actually I had to replace my harness twice. The other time it got pinched under the intake, I was careless routing it before I replaced the intake.
