1.30 60ft but...
Outlaw 10.5 Director
1.30 60ft but...
My suspension sure does suck! I am working on it though. It is a good thing I got a trans brake, too bad I have never been able to use it. With some helpfull advice from Bob at NRC Motorsports I should be cutting some clean high 1.2X's with no wheelie bars this year.
So, who is cutting 1.2X to 1.3X 60ft times and what is your set-up if you don't mind sharing.
Thanks!
Tom
Thanks!
Tom
Originally Posted by Big Mike
Awesome 60'! What's your current suspension set up?
Tom
Originally Posted by 427
OUCH.... your killin me
Running that fast without wheelie bars is kinda scary, you trying too run drag radial races with the NMCA or PRO?
Kurt
Kurt
I have been a fan of the NMCA EZ Street and PRO Extreme class and what those cars are capable of doing without wheelie bars. I really like Bob Currans vette.
Tom
IF you have a Anti Roll like the wolf, I've seen em twist up. IF it was solid there should be no way the car can twist that much. Something else for you to check out. Isn't Bob's Curran vette fairly low. The low stance helps a bunch from pulling the wheels so does the longer wheel base
1 Post
1.39 60's here only motor with a 346 ci LS1, nice even wheelies, 0 body flexing/twisting.
REAR SUSPENSION:
QA1 Rear Shocks
Stock Springs
Wolfe Anti-Roll Bar
BMR Boxed Subframes
Mad Man LCA
Mad Man PHR
LG HD Torque Arm
12 Bolt Moser Rear End /w Spool
You definately need to get your suspension nailed down. I would almost think you have that Wolfe bar installed wrong. I used to pull the left front like you are until I put the Wolfe bar on my car. Now both wheels are level and straight.
Lee
REAR SUSPENSION:
QA1 Rear Shocks
Stock Springs
Wolfe Anti-Roll Bar
BMR Boxed Subframes
Mad Man LCA
Mad Man PHR
LG HD Torque Arm
Lee
6600 rpm clutch dump of death Administrator
Something is up with the anti-roll if your car twists up like that. We had a car that would twist up badly, we put on the anti-roll and the car leave very squarely now. But, I have seen the anti-roll bar twist in some cars if the stock isn't thick enough, and I have heard of some of the aluminum ears deforming on others. A good solid bar with welded ears should keep the car square as long as the other parts of the suspension aren't binding, etc...
Here is a pic of the car I am talking about with the anti-roll in place and working properly...
LS1Tech Co-Founder
Gosh that track sure looks familiar. I like how Wes first set up your torque arm.
Bob Currans Corvette is very nice but since he has ladder bars, does he have an fully adjustable suspension? Also his car is pretty low in spite of the fact he runs some tall tires.
anti roll,
Originally Posted by FSTR-THANU
That's the scary part, I have one!
Tom
Tom
http://community.webshots.com/photo/...02470247ukuraI
Almost as bad as mine. I was hoping a sway bar would smooth my launch out. Now I'm wondering
sway bar
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
BMR anti sway bar, hals, and air bags. mine leaves and lifts perfectly straight now, high 1.2x 60's/low 1.3x's are the norm for me. i am sure you'll get it sorted out.
