drag shocks on street?
Old 04-11-2010, 09:41 PM
greatskiiiier's Avatar
Default drag shocks on street?
who runs drag shocks on the street? after doing my research i like the idea of the comp engineering 3 way adj shocks/ summits version
but how do these perform on the street? id like to get rears now and fronts later in the summer but if these will make my car suck to drive on the street (where it is 95% of the time) i guess ill have to find a new alternative
Old 04-11-2010, 09:47 PM
jakes4321's Avatar
I have the comps set at 50/50 and they are fine. If the roads suck you will feel like a bobble head but 95% of the time they are not bad at all.
Old 04-12-2010, 01:07 AM
My4mulabird's Avatar
i have the summit racing version on the same setting
Old 04-14-2010, 07:15 PM
AChotrod's Avatar
A lot rougher than stock but tolerable. I would NOT want to dd with them though. Would get annoying after a while.
Old 04-14-2010, 08:07 PM
StealthFormula's Avatar
I have the Comp. Engineering 3-ways out back set to 50/50. The rear is a little harsh over bumps and unfortunately PA has quite possibly the worst roads in the country. When the road is smooth they ride really well and I have no complaints, I actually like the added firmness. I primarily drive the car around town and on 50+ mile trips to the track and I for that they suit me well but if it were my DD I would have put my stock shocks back in. I can tolerate alot (rod ended suspension, dumped TD's, real lopey cam) but I really would not want those shocks on a car that gets driven alot.
Old 04-14-2010, 11:13 PM
jakes4321's Avatar
I drive my car alot and these shocks arent bad at all. I put about 400 miles on my car last week and I would complain more the sewing machine sound coming from my valvetrain.
We all will put up with different things
Old 04-14-2010, 11:41 PM
conde'strans's Avatar
Whats the part # for the ones you have? Those the 2755's?
Old 04-15-2010, 11:24 AM
They are the 2700's.
http://www.summitracing.com/parts/CEE-2700/
Old 04-15-2010, 09:13 PM
1qwkz's Avatar
i dd mine at 70/30 isnt bad, youll be fine!
Old 04-16-2010, 10:06 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
spend the money right the first time and get Strange or AFCO adjustable shocks. they will last a long time and are externally adjustable unlike the Comp, but will cost a bit more. its as simple as reaching behind the tire and turning a **** to make the car switch from race to street valving. we have run the adjustable drag shocks on our shop cars for a long time and there is no real reason not to use them if you are looking for performance. we have the best deals on any suspension components you may need. pm or call us for a quote.
Old 04-17-2010, 05:56 PM
99Bluz28's Avatar
Smile
If you going with drag shocks on the street then get a set of Double Adjustable drag shocks. That way you have a better chance of having shocks that you can tolerate driving on the street with.
Old 04-17-2010, 07:21 PM
What setting is more for the track and more for streets?
Old 04-29-2010, 10:50 PM
bore.me's Avatar
I'm very interested in this thread. Lets keep it going!
Old 05-03-2010, 06:11 AM
omcar's Avatar
I have race (r) series QA1s all around set at 3/5 on the street and 1/5 at the track. Last time out in the heat went 1.64 1.64, 1.64. QA1s work. Spohn has them. Speak with Steve.
Old 05-03-2010, 07:29 AM
UMI Sales's Avatar
Hello
I noticed you are looking into a set of adjustable shocks for both on the street and strip. And I just wanted to throw this out there for you that UMI Performance offers both single and double adjustable QA1's. If you are looking for a nice easy shock I would suggest the single. They are pre valved 12 settings for compression and rebound. But if you need that extra 10th and are looking for the extra edge. Then that is when the double adjustable shocks come into play they have a unlimited # of settings seeing how you can fine tune the adjustments for your compression and rebound. Below is a link to show you what I am explaining.
http://www.umiperformance.com/catalo...j1rt5sc8s114m5
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Old 05-03-2010, 04:44 PM
00pooterSS's Avatar
X2....
Getting these and will be running them on the street too
Old 05-20-2010, 06:39 PM
Originally Posted by 00pooterSS
X2....
X3 I'd like someone that has run these at the track to answer this question. I already have them on and set them at 70/30 but havn't taken it to the track yet.
Quick Reply: drag shocks on street?
