Help Converting EFI Live Tune to HP Tuners Format!!
Help in converting EFI Live tune to HPTuners format
Ok heres the deal, I have a 2006 M6 GTO with a Magnuson 112H installed by Lingenfelter. The car was tuned by LPE with Efi Live. I experienced a stock Cat failure and took my GTO into the stealership where they flashed my GTO. Now my LPE tune is gone, but Lingenfelter said they could send me the EFI Live Tune of my car. The only problem is I have HP tuners Pro. The car was NOT tuned with a custom Efi Live OS. The Stock OS is what LPE modified.
So im looking to find someone who could convert the file over to HPT format for me, or someone who owns both EFI Live and HPT as well as an 06 M6 GTO.
If i find someone who has both i could send them the EFI Live File. They could then upload that tune into their PCM. Pull the Tune out by Reading Entire with HP tuners and email me the tune back. Thus converting the file from EFI Live to HPT.
Anyone have any other suggestions for converting the tune???
I do think I was working with a COS
So can someone email a tune and someone open it with the other software or does it have to be loaded in the PCM first?
Can't you just open the tune, and then column by column, row by row, transfer it over to HPT? I am sure you would be happy to have it done by itself, but if they send you the file in EFI format, HPT won't be able to open it, so I think this is your ownly option, unless you find someone who can load it via EFI.
I also have a efi live tune that I would like to be able to convert into hp tuners format. So I can re flash my truck with it. I have already unlocked my truck with hp tuners and don't know anyone that has efi live. You figure out any way to do this?
What the OP wants to do will work but you don't need GTO or an M6. You just need someone with both softwares and an ECM that will take the tune file, ie any vehicle with the same physical computer as the 06' GTO in question. For instance, if I have someone email me a tune for my 2000 Z28 in EFI live I can write it to my 2002 Silverado. Then I can hook up my HP tuner to the 2002 Silverado read the file and walk over to my Z28 and write it to the Z28. Of course you will need licenses for each vehicle and OS and don't forget to put the original tune back in the Silverado or it won't run. LOL
