what else do I need for lt install.
The car 1998 formula a4 with 3:73's and lm1 catback. Just traded an rc car or unknown brand of stainless long tubes race style off a 99 t/a. What all Will I need to make these work? Do you need two 0'2 extension's or one? What cheap y-pipe work's with lm1 catback?
Before you get a Y pipe you need to know which headers you have unless you don't mind modifying the Y.
All Y pipes are not all the same, just as all header collectors are not angled the same once installed.
Look into replacing motor mounts also.
As stated figure out what brand they are before you get a Y or you could have a good exhaust shop fab you one up with a flowmaster merge. Poly motor mounts are a good idea too, you will probably have a banging Y if you don't... I sure did.
Yes i would in this case. A plug and play extension would be a lot easier for 90 percent of people. You'll need a pair, one for each side O2. BUT OP you could do what he said if you feel like playing with wires.
