Where can you buy paint at?
Are you looking for touch up, quart, gallon are you looking for a one part or two part paint. Need more info as to what you are doing. My buddy has a shop in NE pa. We can probably help you out.
Less than a gallon for bumper and hood. Are you painting this yourself? What type of spray gun are you going to use? Do you want a single stage which is a one step with the clear or a two stage one paint one clear coat? I recommend the latter.
No offense, but if you don't know were to get the paint do you think you should be painting it yourself. Either way there are lots of paint supply stores, I use oriellys. If you use a dark colored sealer, or don't have to cover the whole panel you shouldn't need more than a pint of paint
Ok man,
Really it depends on what paint your spraying as to how much you will need.
1)Certian paint covers better than others i.e. Chromabase (DUPONT paint) is a 1 to 1 reduction with reducer and covers much better than Nason (DUPONTS economy line which is sold at O'Reillys) and Nason paint is a 2 to 1
2)What brand of gun you are using.
3)Air pressure you are using through the line
It goes on and on and on man
Look like I have said to a couple of people on the board Paint and body work isnt really one of thoes things you can just hop in and do. It takes a long time and a lot of patience
Sherwin Williams stores can get it in or they will have a store set aside just for automotive and they can give you tips and much more! that's where i got my stuff to fix my stuff i need some more some stupid lady rear ended me this winter no damage then spider cracked now! i can get you a 40% discount there if your interested pm me
