Drag Racing Tech
Stock drive shaft
Old 04-23-2010, 10:19 AM
Mustang Hat'r 2's Avatar
LS1Tech 20 Year Member
Default Stock drive shaft
What are the limits of it? M6 car slick and dumps 3.73 gear 3500 race weight.
Car should have about 340 rwhp, stock LS6 with headers and duals. Where can I get a replacement thats cheap, $300?
Thanks
Jay
Old 04-23-2010, 02:03 PM
Alias Dano's Avatar
Thanks
Jay
I ran my stocker for awhile with 420hp and 1.5 60fts with no problems, I eventually went with a aluminum 3.5 built for $420...
Old 04-23-2010, 06:18 PM
Carter01's Avatar
Thanks
Jay
I've seen them hold like post #2 with 420 hp and I've also seen them get ripped in half with 300. I just took a PST 3.5 out of my car when I swapped over to a Th400 from the M6. I am running a Moser 9 with the big 1350 joints, should be the same as your 12 bolt. PM me if you are interested in it. Was about $500 new from Bob at EPP, I will take allot less.
Andy
Old 04-23-2010, 08:12 PM
rickou812's Avatar
I am still running a Stock ALUMINUM ds... times in sig. But of course this is a auto car and foot braking only.
I am scared to leave off the 2 step and t-brake
Old 04-23-2010, 10:34 PM
Need to fix the sig. That car is long gone. Have an 00 roller coming next week that will have a 9 in it, either will be bought used or built. This car will also be an M6 on slicks leaving with a 6K dump. 500hp on spay and it will break, oh well
Jay
Old 04-24-2010, 11:14 AM
383racecar's Avatar
Im running a stock drive shaft with original front U-joint, going 9.4s@14x.xx 1.31 60fts, 3450lbs car, with T-brake.
Old 04-24-2010, 12:02 PM
FST SS's Avatar
when I installed my 9" I looked at my stock DS and it was twisted about 1/2". That was with stock motor and no slicks, just street tires. I replaced it with a fabbed steel one.
Old 04-24-2010, 03:58 PM
rickou812's Avatar
Was that the Aluminum or steel one?
Old 04-24-2010, 06:12 PM
kline454's Avatar
Originally Posted by rickou812
was that the aluminum or steel one?
i hope its steel!!!!
Old 04-24-2010, 06:15 PM
383racecar's Avatar
Its steel..
