LS oil pan on LQ4
Old 04-28-2010, 06:25 PM
mjollnir's Avatar
Default LS oil pan on LQ4
Can someone confirm any LS oil pan will fit an LQ4 ?
Old 04-28-2010, 06:45 PM
01ssreda4's Avatar
Yeah i but I think you need the corresponding pick up tube to match the specific pan.
Old 04-28-2010, 07:07 PM
Pharcyde50's Avatar
The LS1 oil pan and pick up will work fine. You will be 1 bolt short for the Alternator you can drill and tap it or run without it. I've been running without the bolt for 2 years and no problem. Enjoy the extra displacement!
Old 04-28-2010, 07:09 PM
mjollnir's Avatar
Thx guys!
Let's browse craiglist
Old 04-22-2012, 11:02 PM
33custom's Avatar
I have an lq4 block and cannot get this to fit [img]/Users/amydesimone/Desktop/dim_oil_pan_ls1_camaro-910x882.jpg[/img]
this is the part number... 12581810 i bought the corresponding pick up and the pick up interferes with the pan mounting to the block
Old 04-22-2012, 11:22 PM
01ssreda4's Avatar
Looks like that's an LS2 pan and its more shallow then f-body pans. Can you fix your pic? You are prolly hitting the windage tray. I tried to put an LS1 pan on a 5.3 and it would not work with the truck windage tray.
Old 04-23-2012, 07:14 AM
garys 68's Avatar
All pans fit all LS engines if you use the pickup, windage tray,dipstick, and tube.
The truck windage tray is fill length, f body is shorter.
Old 04-23-2012, 07:24 AM
JaYZeig's Avatar
when i did my lq4 swap, i had to swap over the oil pan, pickup tube, and windage tray all together.
Old 04-23-2012, 02:03 PM
33custom's Avatar
i bought the pan the pick up and cut the truck windage to the correct length, the pickup is still hitting the pan at the from where it is shallow... maybe summit sent me the wrong pickup?> it is significantly smaller than the truck pick up so i am not sure...
Old 08-28-2015, 05:45 AM
Deon Forby's Avatar
Default Wanted
Looking for a ls1 oil pan
Old 08-28-2015, 11:18 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Welcome Dean to LS1tech!
Oil pans for these engines are vehicle specific. What vehicle is your engine in or going into?
Have a look here: https://ls1tech.com/forums/generatio...g-threads.html
Quick Reply: LS oil pan on LQ4
