Driver side tire flush with q-pannel passenger in 2 inches any ideas??
I just baught this 2000 ss and was lookn her over and noticed the drivers side rim and tire are out bout an inch a little past the qaurter pannel and the passenger side tire is in past theqaurter 2 inches some say shed been wrecked but an alighnment guy said it was in the rear end it's got 4:10s any ideas thanks
Thanks for they reply.when the alighnment guy measured evrything he said evrything was sqare he said it seemed to him it was in the gears the rear end is in line but I'm get in there and measure my self to be shure it rides perfect no wabble or noises just looks like Joe dirts car on driverside and looks way in on passenger
Panhards straite looks good diddnt get a chance to do any measering got dark but evrything looks good I'm not really that familiar with rearends or susp. But I know this can't be write
Needs an adjustable panhard. Your alignment guy is rehtard if he thinks the gears have anything to do with centering the rear on a solid axle car. You should set the rear end in the center then have the front aligned to match.
If the car has been lowered at all you definitely need an adjustable panhard bar. That's probably the case here. Either aftermarket springs, the spring isolators removed, or possibly just that much sag in the spring. Check the ride height.
I really don't think it's been lowered cuz it sits pretty high but il measure post the measurements that rubber stop between the botty and axle not shure what it's called but both sides are rotted and falling apart
