just bought 99z28 rear end noise?
basically lil bit of a faint kinda grinding low tone and also kinda sounds like a wheel bearing noise coming from the rear should i be worried the cars in great shape with 108k on it its got the 2.92 rear end auto trans i bought it for $5200.00 today but im hoping it'll last long enough so i can raise the funds for a 12 bolt. any thoughts?
It might be a bearing, most likely the pinion bearing.
On mine it was a pinion bearing making a slight groaning noise.
I had a local rearend shop called " Hoopers " put it new all bearings, seals and a crush sleeve for a little over $200 total.
Yes that was it ... everything else was perfect, I have the Torson posi.
Mine only had 75K on it at the time. The first owner before me never changed the rearend oil, that's why I figured the pinion bearing went bad.
I now have about 84K and the work was done in October 2007.
thanks man i was gettin pretty worried about this but. maybe there is light at the end of the tunnel. but i think that thats probably why i got the car for 5,200. if its a cheap fix then i made out
They will be able to do all the work with the rearend still on the chassis so it's should be fairly easy for a rearend shop.
A cheap fix is not a bad thing. The 12 bolt I need with all the goodies is close to 3 grand shipped, so I figured I'll save the money for now and do a few home repairs. lol
yea 12 bolt is pricey but i hear its worth it ive got a few people lookin out for 1 for me hopin to get it from a totaled car or even a decent 10 bolt with a better gear ratio cause the z28 i bought has 2.73 gears kind of odd for a z28 i hear, but i want somethin like a 3.23 or 3.42 ratio axle
