anyone running a th400 and 3.23 gears
i currently am running 3.70 with a th400 in my DD... i have some 3.00 gears to go into the 9" sitting here... cant wait to get them in, just have to get the time.
You'll be fine....
You'll be fine....
its not so much trans and gears, but that the engine (cam, tire size, rear ratio, etc) converter are all setup to work together-change one item and your stall will change-i ran a 400 with those gears, but installed a 2.75 gear set in the trans, gave me a little better take off, but in 3 rd i still had some good cruising RPM,s
thanks
