3.90's or 4.10's
3.90's or 4.10's
I'm considering a gear change for my 02 TA M6 (Non-DD) and I'm curious what opinions you all have on which gears I should go with...3.90's or 4.10's? Stock 10 bolt fyi. I will not be drag racing the car, stricktly around town cruiser.
Ive run both gears and the 4:10 is the best for cruising you can pull out in second gear from a dead stop ,but you will blow the tire off if you decide to play, The 3:90 gear is a good highway gear and not so harsh on the tires ,but a step above the 3:73's. And the 3:90's are a little stonger , because of the pinion size .
