Correct part number for u joint
Old 05-10-2010, 01:44 PM
Yahelou's Avatar
Default Correct part number for u joint
So i have been searching for part numbers for u joint and i am getting different ones. my car is a 2000 Camaro Z28. stock driveshaft, 10 bolt.
i searched on napa's store and this came up: http://www.napaonline.com/Search/Det...+50012+2012008 is it correct? i wanna replace both u joints, will this part work for both?
Old 05-10-2010, 02:17 PM
99ssleeper's Avatar
correct, both the same
Old 05-10-2010, 02:22 PM
Yahelou's Avatar
thanks. does anyone know which one is better, this one or the striker one?
Old 05-10-2010, 02:44 PM
Jawsgear's Avatar
I would run a Spicer or Neapco Ujoint. These cheap i,port ones from the auto parts stores do not seem to hold up and last.
Old 05-10-2010, 03:42 PM
Yahelou's Avatar
ok, so i found this thread:
https://ls1tech.com/forums/gears-axl...-u-joints.html
i was originally gonna go with spicer. dont know why i changed my mind
is the spicer 5-795X the correct part number for the stock driveshaft, 10 bolt? and will it work for both sides?
i did find this Neapco part also at advance: http://shop.advanceautoparts.com/web...S_634231447___
or is it this one: http://shop.advanceautoparts.com/web...S_634234461___
Old 05-11-2010, 09:07 AM
Yahelou's Avatar
so is the spicer 5-795X the correct part number for both u joints?
Old 05-12-2010, 11:50 AM
99ssleeper's Avatar
both u joints are the same for a stock d/s, yoke, and rearend. if 5-795x is right for one end it'll fit the other.
Old 05-12-2010, 01:38 PM
Yahelou's Avatar
thanks buddy.
Quick Reply: Correct part number for u joint
