Codes 36 and 42
Codes 36 and 42
Started up the new motor this weekend. Had an instant SES light on. Car isn't tuned yet for this setup, but was tuned for last setup(355/ported heads/cc305). We used the old opti, wasn't having any problems before. Little help?
95 Z28
385
Ported stock heads and intake 2.02/1.60
58 mm TB
42lb SVOs
Lunati 60123
Thanks
Sean
95 Z28
385
58 mm TB
42lb SVOs
Lunati 60123
Thanks
Sean
36; High Resolution Pulse Circuit (Check Opti pigtail first, persistent return after clearing accompanied by driveability issues = new Opti in your future)
42; Ignition Control Ground Circuit (check ICM wiring, test resistance using shbox's procedure: http://shbox.com/1/4th_gen_tech2.html#opti_test)
If everything looks ok after troubleshooting, reset the PCM by disconnecting batt. ground for a few minutes and then drive and look for the return of codes...
Best of luck. This pair of codes ended in an Opti replacement for me a couple of weeks ago.
