how to depin connectors (gauge console specifically)
Old 05-10-2010, 10:25 PM
merim123's Avatar
Default how to depin connectors (gauge console specifically)
any tips for how to depin these little things. I'm thinking i can do it with a small screwdriver, but wonder if there is an easier way to do this. I'm trying to depin a harness for my lt1 to move my dash over to an ls1 type dash.
Old 05-10-2010, 10:30 PM
Bigugly's Avatar
matco and snap on make tools for this, I cant remember what they are called but I did see them on the tool truck.
Old 05-11-2010, 08:19 AM
merim123's Avatar
Thanks, i'll have to see if i can find one of those trucks around. is there an official term for the tool besides depin? i'm trying to search everywhere and not getting too many hits on depin.
Old 05-11-2010, 09:56 AM
Pop N Wood's Avatar
http://www.repairconnector.com/produ...-3-Pieces.html
Radio shack carries extractor tools also
Old 05-11-2010, 11:13 AM
stealth71's Avatar
I usually use a paper clip.
Old 05-11-2010, 11:51 AM
merim123's Avatar
i tried the paperclip route, must be putting it in the wrong place, where is the tab being accessed from to release it?
Old 05-11-2010, 10:35 PM
Mike52's Avatar
I've been taking pins out of wiring connectors for years without 'special tools'. Depending on the type of connector I'm working with, I've used a tiny eyeglass repair screwdriver or a safety pin that's been straightened out. You can't use the same tool on a Packard, Deutsch, Amp Multilock, Molex, etc connector but you sure can use the tiny screwdriver or safety pin!!
Mike
Old 05-12-2010, 05:54 AM
Pop N Wood's Avatar
$7 for a set of three extractors. At some point you have to ask what your time is worth.
Old 05-12-2010, 08:17 AM
merim123's Avatar
i agree, i'll be buying the tools, just in a time crunch right now. need to get the car out of the garage so i can get the concrete poured
Old 05-12-2010, 08:46 PM
merim123's Avatar
figured it out. really simple once you see how one comes out. took all of 5 min with one of those eye glass screwdrivers. did it without damaging and figured out how to pin them back so they are tight. now i understand why a paperclip will work too, but this little eyeglass screwdriver was pretty perfect, doesn't give us much as a paperclip.
thanks again guys!
Old 05-14-2010, 09:08 AM
merim123's Avatar
my gauge cluster swap over was a success.everything works! now need to get the dang dash in!
Old 05-18-2010, 08:26 PM
Mike52's Avatar
thanks again guys!
As I said, no fancy 'special tools' required, glad it worked for you.
Mike
Quick Reply: how to depin connectors (gauge console specifically)
