Erase codes from Scanmaster?
Picked up a scanmaster for my lt1. Has some trouble codes stored into the scanmaster. Unplugged the battery terminals and still codes pop up. Does anyone know how to erase these codes. Is there a button I could push or fuse to pull to erase them?
The code will erase if you disconnect your battery, but if the issue is still there, then the computer will flash your SES light again. You need to determine why the code is coming up, and fix it for it to go away.
I tried disconnecting the battery for 30min. The scanmaster still pops on a couple codes without even me starting the car up. When I first hooked it up the codes were already stored in the scanmaster. DTC 55 DTC18 pops up. But like I said I just turn the ign. on and I'm getting those codes - Is there anyway to erase this codes
