Compare Nick Williams & PTM 102 mm Throttle Body's
Old 05-14-2010, 04:50 PM
RedHottG2's Avatar
Default Compare Nick Williams & PTM 102 mm Throttle Body's
I am getting either the NW 102mm or the PTM 102mm TB. There is only a $100 difference between the two and I just need to know if there is ANY difference between the two ? If not I would for sure save $100 to put towards my FAST 102 intake.
102mm PTM Throttle Body:
http://www.texas-speed.com/shop/item...d=891&catid=73
Nick Williams 102mm
http://hinsonsupercars.com/p-1158-ni...e-by-wire.aspx
Old 05-14-2010, 04:57 PM
AES Racing's Avatar
Old 05-14-2010, 04:59 PM
RedHottG2's Avatar
^Thanks a lot
Old 05-14-2010, 05:01 PM
AES Racing's Avatar
for 1, both throttle bodies are same price
the nick williams throttle body you're looking at is Drive by Wire.
Old 05-14-2010, 05:04 PM
RedHottG2's Avatar
OK thanks for making me aware of that. So what does that mean ? which do I need for a FAST 102 and my 2000 Z28 ?
Old 05-14-2010, 05:11 PM
AES Racing's Avatar
with an Fbody you need a cable throttle body.
Old 05-14-2010, 06:11 PM
Soul TKR's Avatar
This is the correct Nick Williams throttle body...
https://www.vengeancerd.com/ecart/pr...-Throttle-Body
as far as the difference I'm not sure. I've heard glorious things about the NW's one... never hear much about the PTM. Not to say it's not a good piece or anything...
Old 05-16-2010, 01:50 AM
ls1 1990 VN's Avatar
Have any of you guys fitted a 102mm tb & how has the tuner gotten on with tuning. I am also looking at the NW 102 tb compared to the PTM 95 with a Fast 102 intake. A guy only gets 1 chance of getting it right on this side of the world so info from you guys is invaluable.
Cheers
Old 05-16-2010, 07:15 AM
SweetS10V8's Avatar
Yout wont see any benifit from running the 102mm throttle body over the 92mm throttle body on the FAST intake(with your combination).
Just get a 92mm throttle body. I'm running a 90mm TB on my FAST 102.
The 102mm throttle body requires some clearancing either on the throttle body or water pump on F-bodies. The 92 does not.
Old 07-24-2014, 06:35 PM
Craig Chamboullides's Avatar
I'm running a 102 ptm on an 02 Camaro no clearance issues outside making room on the overpass tube. Haven't gotten a good tune in it yet but it's a good looking fitting piece
Old 05-06-2016, 09:21 AM
JRMClassics's Avatar
Would like to get $350 for it.
Old 05-06-2016, 08:47 PM
King23's Avatar
I have the NW 102 it's a nice piece, seems everyone runs NW too.
Old 05-08-2016, 01:37 AM
1970camaroRS's Avatar
Ancient thread guys...
Old 05-08-2016, 08:51 AM
King23's Avatar
I hadn't even noticed the date seems like a lot of threads are coming back from the dead lately, my bad.
Quick Reply: Compare Nick Williams & PTM 102 mm Throttle Body's
