61 tooth 5th gear?
Old 05-14-2010, 10:24 PM
jeeperanthony's Avatar
Default 61 tooth 5th gear?
Does anyone have a link or a part number for a 5th drive gear with 61 teeth? It came out of an 05 -08 vette T56, and my supplier is having trouble locating it(also having a problem with being pleasant, but that's another story.
Old 05-14-2010, 10:34 PM
85MikeTPI's Avatar
Here's a thread for reference:
https://ls1tech.com/forums/manual-tr...gear-swap.html
If it's definitely from a vette, then it would almost certainly have to be a Z51 (MZ6) optioned unit. Since it's a GM-only unit, you most likely have to get it from a GM dealer. If it's from an '08, then it's not a T56, but a T6060.
Old 05-14-2010, 10:48 PM
Does the T6060 look like the T56 Case?
Old 05-15-2010, 06:18 AM
85MikeTPI's Avatar
Yes, very similar in looks, but nothing really interchanges. The most notable change in the vette unit is the integrated front fluid pump (T6060) vs the bolt-on pump (T56).
Old 05-15-2010, 09:21 AM
Well then I know its the T56 because there is not even any ports on the midplate for a line. I'll call around and see if I can get any info on where to get the gear I need.
Old 05-15-2010, 09:54 AM
thesource's Avatar
Are you looking for a new gear or used one? Whats wrong with the gear you currently have?
Old 05-15-2010, 10:43 AM
Im tempted to just stay out of 5th gear. Also, will a F body main shaft work on these gears?
Old 05-15-2010, 12:43 PM
thesource's Avatar
Honestly that gear would probably be ok to reuse if you have to. If you have the time and money, I would go ahead and replace it just to have a little piece of mind.
Old 05-15-2010, 06:52 PM
LS123's Avatar
Is this trans out of your Vette? The midplate shows where the front mounted fluid pump would bolt to. Another easy way to tell if you have a pump or not is to look at the front of the cluster shaft, it should have a "slot" cut into the front where it drives the pump.
Old 05-15-2010, 08:36 PM
Not out of my vette. Know the guy who pulled it though, and he knows what a vette looks like.
Quick Reply: 61 tooth 5th gear?
