a4 gear question ASAP !
Old 05-17-2010, 09:10 PM
Pate_2008's Avatar
Default a4 gear question ASAP !
I have a 4l60e with a yank 4000 will be running a 28" tall tire. Spraying a 125 shot and i have a 233/239 cam l92's ls3 manifold should i get a 3.73 gear or a 3.90 or what?
Old 05-17-2010, 09:19 PM
69_YENKO's Avatar
I haven't installed everything yet to test out the combo but after looking at some gearing calculators I went with 3.90's for mine.
4l60e/ SS3800/ 28" tire/ 150-200shot/ tfs235's
with the 28" tire I wanted the extra gear, if i was staying 26" i would have just gone with 3.73s
Old 05-17-2010, 09:24 PM
Pate_2008's Avatar
ok i just wanna make sure. because i will be spraying and going through the traps in 3rd gear and dont wanna run out of gear
Old 05-18-2010, 05:51 PM
MikeG's Avatar
It depends on how efficient your converter is. The 3.90s could be close, the 3.73s should be more than fine.
Old 05-19-2010, 07:07 AM
SS SLP2's Avatar
My cam is smaller (231/237) same tire/same yank will shift @6500/limit @6700 I will install 9"/4.11 with next week or so only hope I can make thow the traps with out going into OD, so will find out later which gear is best.
last year with 10 bolt/3.73/25.5 tire trapping 124.5
Johnny
Old 05-19-2010, 10:13 AM
Silver LS1's Avatar
I went 10.50 at 130mph, with a 4400 converter and gobs of NOS. I would make sure you can lock up the converter in drive (3rd gear), and run a 4.10 gear. Then converter effiecency isnt a factor. 3.90s will be fine too. If you stick with slicks, a 4.10, if you run radials then a 3.90. Hope that helps!
Old 05-19-2010, 10:22 AM
STEEPSS's Avatar
You'll soon know I guess!
When ya gonna have that beast up and runing?
Old 05-19-2010, 06:35 PM
Pate_2008's Avatar
well hope to get the rear all put in on the 29th when i get home and it will be out again.
