Deleting My A/C.. Have questions
I am looking to delete my A/C system and retain the heat in my 01' SS seen as I got the new Chrs1313 ram air kit to go in. I have searched pretty extensively and have not found the answers to the questions I have.
1. How do you drain the system before removing everything? I am looking for a specific answer here, not just "oh go look at it and you'll see blah blah"
- Is there a valve somewhere?
- The only thing I have found concerning this is you can do it at your own house and doesn't really need to be professionally done.
2. Will I need a new pulley to take the place of the A/C compressor after I remove everything?
- My guess is if I just remove the compressor only the compressor bracket remains place, which has the correct pulley already. Am I correct?
3. I haven't seen a good decent write-up yet, I have seen HeyFreds, but his is mainly from the firewall and doesn't show anything up front, just trying to make sure I didn't miss a good step-by-step process already.
thanks guys
thanks guys
If you want to kill the environment, you can simply wrap a rag around a philips-head screwdriver and empty it out via the schrader valve near the drier. If you choose to do this, don't freeze your hand, wear safety glasses, and consider a flak vest, so you don't get taken out by an EPA sniper.
You'll make a baby harp seal cry though, so I don't recommend it.
Have fun.
Don't say you weren't warned when the EPA sees this post and shows up with the battle wagon...
Make sure the valve is the low pressure side and do it in a well ventilated area. I did it in my garage and after I got done I was a little light headed. Probably a little high from the stuff. lol. And yes that **** will freeze your hand. Use a thick towel/rag.
-Mark
-Mark
Unbolt the line from the dryer or condenser and let it bleed out. Ive never done it im just sayin. You dont need a pulley because the crank pulley turns the A/C unit on a seprate belt. If you pull the dryer, condenser, lines and the actual A/C pump then you wont lose your heat. heat is run by a seprate system. Why would you want to do this anyway. I bought my car from a guy that pulled the A/C out of my car and it was all fun and games until the summer rolled around. For some reason you just dont look good in a car when you step out and you have the whole *** sweat butterfly thing going on no matter how bad *** the car is. Oh and you can forget a chick wanting to ride. I never realized how valuable A/C was until I went without. Im just sayin.
Well I have to get rid of it so I can put on the Chrs1313 Ram Air Kit (Sold by Speed Inc)
Armyboyatc, I'm assuming by your screen name your an air traffic controller.. same here in the Marines.. how is it in the Army? I'm gettin out and doing ATC as a civilian contractor overseas makin 130g starting with first 90g untaxed =)
Thanks everyone for your answers. I'll probably just un-do a line slowly and let it gradually drip out to prevent a huge mess.
I can't believe so many of you guys just vent it into the atmosphere. Do the right thing and take it to a shop and they can recover and evacuate your system. Don't be a douchebag.
