TRex and PP Stage 2 5.3L Heads PTVC?
Old 06-03-2010, 12:55 PM
sujomatt's Avatar
Default TRex and PP Stage 2 5.3L Heads PTVC?
99 Camaro Z28
Stock bottom LS1
TRex v2 Cam (242/248 - .608/.612 - 110 lsa)
Patriot Stage 2 5.3L Heads
Hardeneded 7.4 pushrods
LS7 Lifters, etc etc..
Do you think I will run into any issues with the Piston to Valve clearance??
Is this easy to measure? On Heads on, etc?
Thx in advance!
Old 06-03-2010, 03:01 PM
Paint_It_Black's Avatar
Originally Posted by sujomatt
99 Camaro Z28
Stock bottom LS1
Thx in advance!
Yes, you'll be fly cutting that combo. No doubt about it. Cutting .080 would probably be safe.
Old 06-03-2010, 05:09 PM
sujomatt's Avatar
Even tho the chamber is 63cc?
Old 06-03-2010, 05:16 PM
bww3588's Avatar
only way is to measure. according to TSP, the MS4 can be ran with stock heads and pistons etc...however the duration is more with the TREX, so PTV might be more of a concern.
measure twice, cut once.
Old 06-03-2010, 05:17 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Last Trex we had come through here the customer ordered our stage 2.5 5.3's...we set them up for the best possible PtoV (premium cores that only need milled .003" and recessing valves slightly)....we typically lose less than .010" on the valve drop compared to stock when we do this. It was WAAAYY too tight for our comfort still! not knowing how they set their heads up......I'd flycut FOR SURE!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-03-2010, 05:37 PM
sujomatt's Avatar
I am not very familiar with Flycutting... is it easy to do with the heads off? b/c they already are... the less work the better - bought these heads not realizing ill probably need it... huge fail on my part.
Old 06-03-2010, 05:44 PM
bww3588's Avatar
the heads come on and off during flycutting. in fact, each head goes on and off 8 times if done right. however, it does not have to be torqued or anything like that, just set on and tightned down with a few bolts. or....if you want to pull the pistons and rods out, you can take it to a machine shop and they can do it with a mill.
Old 06-04-2010, 07:40 AM
sujomatt's Avatar
Yea... So, with that said, I think I may just upgrade the pistons to something with higher compression.
Recommendations?
Old 06-04-2010, 08:17 AM
Recommendations?
You don't use pistons to increase compression.. unless you run a dome, which is stupid in an ls street engine. You gain compression by milling the heads and running a thinner gasket.
So let me get this straight, you would rather pull the engine, buy new pistons, have them assembled, possibly balance the rotating assembly, new rings, a block hone, new bearings and hardware, reinstall EVERYTHING.. rather than rent a fly cutting tool for 50-60 bucks, and spend 2 hours cutting the pistons, which can be done with the engine in the car? That sounds crazy!
Old 06-04-2010, 08:31 AM
sujomatt's Avatar
Sorry that was my Honda experiences showing through hahaha
I guess I'll just take extra time doing the flycutting
Old 06-04-2010, 03:49 PM
SOMbitch's Avatar
Seach the Lindy tool. A bunch of flycutting threads on here too if you search. I think chrs1313 has one he rents out on here.....
Old 06-04-2010, 04:11 PM
garygnu's Avatar
get a custom cam that will fit with out fly cutting.
Old 06-04-2010, 07:04 PM
sujomatt's Avatar
well that would be just dandy if i didnt have the cam in my garage already lol
Old 06-05-2010, 01:33 PM
chrs1313's Avatar
I have the Lindy tool it works great...I pulled my engine to cut but others have had luck doing it in the car...just takes a hair longer...shoot me a pm when/ if you want to rent the tool...
I have intake (good for up to 2.04") and exhaust (good for up to 1.58")...
also I would not build another h/c/i lsx without flycutting the gains in running a bigger cam, higher compression out weigh the added extra couple hours by far...
if you flycut you will be able to run a thinner gasket and or mill the heads to bump the compression even more
Old 06-08-2010, 03:31 PM
sujomatt's Avatar
Would a better choice (no fly cutting) with great power be the MS4 cam? I can probably easily sell the cam instead and save some cash that way and the hassle
Old 06-08-2010, 03:39 PM
You can measure the valve drop (how far the valve travels from its seat to the deck surface or table top) and that would give us the info needed to make that decision...but again, with the limited knowledge I have about the way they configure their heads, I'd bet against it clearing without flycutting!
__________________
Old 06-08-2010, 03:40 PM
00MaroonZ28's Avatar
Just stick to what you've got right now. Flycutting isn't a big deal. It's pretty easy.
Old 06-08-2010, 03:44 PM
sujomatt's Avatar
Yea Ill cowboy up n measure clearances with my buddy once the heads come in (probably this weekend) and stop worrying right now about this lol
Old 06-08-2010, 04:02 PM
That combo will net you some pretty good power N/A.
