LS1 or LS2 in FC RX7
Old 06-04-2010, 02:57 PM
Mike_72's Avatar
Default LS1 or LS2 in FC RX7
Hey everyone, new to the forum and ready to purchase an engine for my FC LSX conversion. I have a couple of questions regarding an LS2 swap.
Based on what I have read up on there are 2 main things to consider when swapping an LS2 motor and T56 into an FC RX7. First would be the need to run an oil pan, windage tray and pickup from and LS1 camaro or firebird and second would be the fabrication required to mount the DBW pedal assembly on the rx7.
Is there anything I am missing here or is it really that simple.
Thanks,
Mike.
Old 06-05-2010, 01:27 PM
Mike_72's Avatar
Also,
Does the LS2 from the GTO share the same accessory package as thr F-body LS1??
Old 06-05-2010, 02:20 PM
squarehead's Avatar
Originally Posted by Mike_72
Also,
nope
check out www.norotors.com essentially an RX7 swap site
Old 06-05-2010, 09:24 PM
Skillet's Avatar
Originally Posted by squarehead
nope
Thanks for the link! I had been looking for something but all that kept coming in google were links to a site that doesn't appear to be around anymore.
Old 06-05-2010, 11:00 PM
tripblackls1's Avatar
yea norotors is basically the new v8rx7 site the old one recently went down
check out the swap kit from pez, he also does the wiring harness conversions to make them plug and play
oh BTW don't bother with the drive by wire tb, get a cable tb and have the harness converted
Old 06-06-2010, 09:25 AM
Mike_72's Avatar
Is there a reason to stay away from the DBW?? I was under ther impression that to convert from DBW to cable throttle I would have to change intake manifold and ECM also.
Old 06-06-2010, 03:47 PM
hayabusa's Avatar
That's true!
Old 06-08-2010, 05:26 PM
Mike_72's Avatar
How is the delay on these LS2 DBW cars?? On my Audi there is a very slight delay between pedal movement and throttle response. Is this an issue with the LS2?
Quick Reply: LS1 or LS2 in FC RX7
