LM1 vs. LM2 bullet muffler
Old 06-06-2010, 08:59 AM
1SWT95Z's Avatar
Default LM1 vs. LM2 bullet muffler
Anyone know how different the SLP LM1 and the SLP LM2 sound? Is the LM2 a better sound since the bullet muffler is a different design? I'm just looking to create a semi custom exhaust with some LM parts(planning to put a LM2 bullet where my cat is and an XR-1 round muffler where it usually goes in a Borlamouth setup, good idea?). Once I do this I'll have a Hooker Aero chamber muffler ready for sale if anyone is intrested. Thanks guys.
Old 06-06-2010, 10:38 AM
TheDon619's Avatar
having both would def cut down the rasp that both mufflers produce at high rpm by themselfs. the LM2 is considered the quiter of the 2 but imo the design is about the same simply with more baffles and packing to make it quiet.
Old 06-06-2010, 07:50 PM
1SWT95Z's Avatar
so you think having the LM2 bullet and the xr1 together would be a good combo?
Old 06-06-2010, 09:30 PM
mean_greenZ's Avatar
SLP LM1: It is basically an open hollow can... not much to be said about it.
SLP LM2: As you can see the LM2 contains packing material with a perforated tube just like a dynomax bullet. The only difference is that the LM2 necks down to a 2.5" internal perforated tube which supposedly helps sound suppression.
I have heard both in person and I can say that if you go with the LM1 you may as well run straight pipes because as you can see from the pic it has nothing in it.
The LM2 is basically a stainless steel dynomax bullet. They sound similar.
Old 06-07-2010, 11:31 AM
1SWT95Z's Avatar
I had the LM1 and then switched the "bullet" to the Xr1 and loved it other than the little bit of rasp. Thats why I'd want to get the XR1 and a LM2 bullet and run them both.
Old 06-07-2010, 01:48 PM
StealthFormula's Avatar
My one buddy has LT's, ORY, LM1 and another has LT's, ORY, LM2 and the LM2 sounds ALOT better. Both are loud and even the LM2 could use a little more tone at times but it definitely beats out the LM1 by a long shot.
Old 06-07-2010, 02:15 PM
1SWT95Z's Avatar
Yeah I was hoping someone would tell me that. I think doing both the LM2 bullet and the XR1 will work well. Now I just need to find a good used LM2 bullet for sale.
Old 06-07-2010, 04:38 PM
yea i would do the LM2 i have heard it and it sounds much better than the LM1.
btw... Stealth i'm liking the sig pic!! nice stance
Old 06-07-2010, 05:08 PM
NewOrleansLT1's Avatar
Why do you want to run 2 mufflers? You are going to create two much back pressure. You might as well get a Flowmaster. The LM2 by itself will give you what your looking for.
Old 06-07-2010, 05:16 PM
jay7199's Avatar
LM2. hate my LM1
Old 06-07-2010, 05:38 PM
1SWT95Z's Avatar
Well I guess I figured the LM2 alone would still be pretty loud, and the XR1 is only slightly better. Plus I figured the LM2 would not create that much back pressure since it is fairly slim and straight through. Would'nt the LM2 bullet act like a high flow cat?
Old 06-07-2010, 06:40 PM
Spartan7's Avatar
I got tired of how loud the LM1 was. Now I have Dynomouth on my T/A and it's surprisingly quiet for a bullet muffler. No drone on the freeway.
http://www.youtube.com/watch?v=8Od4SwJckOQ
Old 06-07-2010, 06:53 PM
1SWT95Z's Avatar
Sounds good. Do you have any vids of it driving? Is the dynomax stainless?
Old 06-07-2010, 08:20 PM
Thanks man!
I don't see that being an issue at all, a bullet muffler is less restrictive than running a set of hi-flow cats.
Old 06-07-2010, 10:27 PM
yea if you run two straight thru style mufflers how is that gonna restrict?
Borla XR-1
SLP LM2
Old 08-27-2015, 01:37 PM
Bigbluff's Avatar
Borla XR-1
SLP LM2
I know this is an old thread, but this question wasn't answered, and it deserves an answer.
The way expansion chamber mufflers work is by slowing everything down, the flow, the sound waves...everything. With it slower it also isn't as loud. It also cools the exhaust gases. The slower moving gases will create back pressure in the exhaust system. Add another and it will happen all over again. It's just physics.
You might get the sound you want, but it will also increase back pressure.
Old 08-27-2015, 01:44 PM
MonmouthCtyLS7's Avatar
Both LM's are loud, The LM2 is less raspy which is the whole reason they made it in the first place. I ran a LM1 on a catted setup on my old LS1 and it never bothered me.
Old 08-27-2015, 03:33 PM
Dirty_Bird's Avatar
Had pacesetter headers to a high flow cat to lm2s and it sounds awesome.
Quick Reply: LM1 vs. LM2 bullet muffler
