More problems...
More problems...
Well i have officially messed up the lt1 for the third time... First time i got it all together, i realized the crank threads were jacked, machine shop put in a helicoil. then i nicked a rod journal, got it turned at the shop. So the other night i was setting the rocker preload and using the crank snout bolt to turn the motor over. I started to pull the bolt out afterwards and it got to where it almost wouldn't turn. It ended up pulling out half the helicoil when i got it out....
I really don't want to take it apart again. I don't even know if it's fixable. Can it be drilled out again and have another coil put in? If i took the whole motor to a shop would they be able to fix it with it in the motor?
And whenever you can help it, you shouldn't use the crank bolt to turn the motor.
Didn't have to take it apart and the machine shop only charged me $25 to fix it. I'm pretty pumped, and ready for this beast to cruise around and get some noise pollution citations
