04 gto A4 belt slipp during 1st-2nd shift??
I am a new gto owner and when i first bought my gto it was bone stock and i had zero belt slip. Now i have added a hardcore cold air intake and now when i am under WOT my belt will slip when my car shifts from 1st -2nd how can i get rid of this problem as i feel i am loosing power and time during 1st - 2nd shifts??
Thx Eric
Thx Eric
any specific brand stock oem or gatorback or does it not really matter?? Also wont it just heatsoak and streatch again is there a stronger tensioner pulley or mabey a better a/c pulley?
I have no clue just throwing ideas out there ??? Seems to be a common problem through
are you sure that it is your belt slipping?? does it make a squeak in between shifts? bc it was happenign to me and it might be your tires making that noise..so i might not be your belt
OP,
Do you have and underdrive pulley?
If so, the belts will be different size VS stock.
Just an idea.
If you are lucky maybe you can read the part # off the existing belts on the car (provided they are the correct size.)
--Glenn
Just an idea.
--Glenn
ya, belt slip won't lose any power as it is just turning the water pump, alternator etc. I'd be more worried about clutch pack slippage in the transmission. Pull your tranny dip stick and take a look at the fluid and smell it. If it's brownish instead of pink and smells burnt start driving less aggressively and start saving up . . .
