pacesetter header install
Try the search function. Works well.
But in any case, use this.
https://ls1tech.com/forums/generatio...otsa-pics.html
Moderator
It's easy. Do a search in the external engine section and you will fine a shitload of posts about it.
Get a friend to help.
car does not need to be that high up. Jackstands work fine.
driver side header goes in facing forward and rotates in.
ARP header studs make getting them in hard.
Get ready for LOUD and RASPY!!!!!!!!!!!!!! I have that same set up and I hate it. I'm going tomorrow and having a resonator installed between the y pipe and the muffler to try and fix it.
