4K Stall w TH400 on MS4 cam car...
Swaping From M6 to Th400 nxt wk, Looking to run 4k stall w trans break on the TH400 w 2step...is this something Im going to be able to drive 45min to the trac w out burning the trans up?.....Probly going to buy a Abruzzi Built Trans
LS1Tech Sponsor
This can be done very easily. Give me a call as we have complete bolt in packages.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
my friend has almost the same set up but with a high stall and drives it from modesto to the bay area which is like a 1hr and 30 min away with no problems what so ever.. and rips ***!
Circle D 4C, TH400, MS3 with 3.73s and 26" tires... b&m 70266 and a 7" fan with the cooler exposed behind the front bumper (camaro) in the left opening behind the grill. With the fan on and cruising between 65-70mph which is roughly 3300-3500 rpm tranny temps stay between 150-160 degrees on my digital autometer gauge. The more i cruised at that speed the trans temps actually dropped compared to when i was in the city.
I drive mine on the interstate, and it's loud, not a horrible drive, but does get a little annoying.
I have a th400, 28" tires, 3.70 rear, FTI 4200 stall. at 65mph I'm around 3200 rpms. it burns some gas! I have a B&M 24000 mounted dope style and on a hot day I'm around 180 degrees
