modded engine bay
Old 06-18-2010, 07:24 PM
01badbird's Avatar
Default modded engine bay
This is what I've been working on-smoothed and filled fenderwells,smoothed cowl,powdercoated and polished just trying to clean up.moved few things (linelock,tcs/cruise,fuses,coolant overflow so racing battery located under stock location)what ya think?
Attached Thumbnails modded engine bay-meet-greet1.jpg   modded engine bay-mifbodymeetandgreet2010880.jpg   modded engine bay-mifbodymeetandgreet2010883.jpg   modded engine bay-mifbodymeetandgreet2010885.jpg   modded engine bay-p6050005.jpg
Old 06-18-2010, 07:45 PM
mannyman84's Avatar
looks good
Old 06-19-2010, 05:13 PM
WS9 Formula's Avatar
looks real good
Old 06-19-2010, 10:17 PM
PontiacFan's Avatar
But I hafta add, ..., IMO, the lid would've been better if it was color-matched also.
Old 06-19-2010, 10:33 PM
99'CajunFirehawk157's Avatar
Looks good but ya should have put this in the engine bay thread for more exposure, IMHO.
Like to see more pics of the rest of your car, is it as detailed as you engine bay?
Old 06-19-2010, 10:44 PM
firemech21's Avatar
Thats looks really good.
Old 06-20-2010, 12:37 AM
jthunderz28's Avatar
one of the cleanest engine bays I've seen on any bird. Good Work!
Old 06-21-2010, 11:49 AM
theapprentice's Avatar
Looks Awesome!
Old 06-22-2010, 12:50 AM
rbaksi's Avatar
that is so smooth. Looks really great love the red.
Old 06-22-2010, 05:38 PM
RedVertTA's Avatar
Awesome. Where did you get the chrome radiator cap and aluminum lip that hangs over the cowl?
Old 06-22-2010, 08:34 PM
Ethan[ws6]'s Avatar
How did you smooth the inner fenders?
Old 06-22-2010, 08:48 PM
meine96ws6's Avatar
wow, that came out great..
fucter's Avatar
Where did you get that gauge pod at?
Old 06-22-2010, 10:11 PM
eseibel67's Avatar
Looks good, but keep going!
Ditch the A/C and ABS.
Old 06-22-2010, 10:33 PM
RedVertTA's Avatar
Where did you put the fuses and line lock?
Old 06-23-2010, 04:14 AM
01badbird's Avatar
the radiator cap is spectre 4338 (autozone can order for you and you don't end up paying shipping)the cover is glued on but had to separate and put back on so didn't set crooked (then ordered three more and seperated to use on oil,brake and pwr. steering and alum lip is 1/2"angle stock from hardware(polished myself).to smooth started by welding up seams then grinding down all high spots then filled in low spots(some had metal patches like where tcs/cruise module and valley on top of drivers side)lots of sanding!the nitrous/ fuel gauge pod I made myself(laid fberglass over two spray can lids to start)so I could watch on runs and always liked the look of the old hood tachs but didn't want to touch hood.If it was all up to me maybe delete A/C ABS but wife needs air and we do use it sometimes cruising around (now wondering about relocating both...)the fuses are flipped upside down(believe I had to disconnect power wire (the thicker ga wire)and reattach after wiggling threw hole where a.i.r. system was.you have to service fuses thru access under car(but how many times do you have to get to?)the linelock was slp (mounted on fenderwell) made bracket that goes to bolt on brake booster and redid lines.bought metric tube (for abs&brake ends (bubble flare)and cut for linelock and those ends take double flare (easier & have tool)
Old 06-23-2010, 06:11 AM
What about those hose clamps?
Old 06-23-2010, 09:05 AM
RedVertTA's Avatar
Could you post more pics of the linelock setup and location and what you did with the fuses?
Old 06-23-2010, 09:38 AM
Storm Trooper's Avatar
looks awesome, very clean!
Old 06-23-2010, 11:40 AM
01badbird's Avatar
heres clamps http://www.jegs.com/webapp/wcs/store...chTerm=141-515 you might need at least 2 sets and will have to switch to worm gear clamps (just covers) but still has GM stamp. the linelock is mounted then hand bend lines,takes some work just like fuses fitting down hole (disconnect battery first) heres some pics if it helps
Attached Thumbnails modded engine bay-jazz-011.jpg   modded engine bay-jazz-168.jpg   modded engine bay-jazz-030.jpg   modded engine bay-jazz-037.jpg
Quick Reply: modded engine bay
