Custom SFC's
Copy & Paste Moderator
trackbird,
Rust is corrosion, but I know what you ment.
Aluminum will form a thin layer of rust (kinda whitish/greenish) but it wont rust through like steel or other iron ore derivatives.
I agreee with the others here that aluminum isnt strong enough for SFC use.
--VIP1
--VIP1
Originally Posted by VIP1
trackbird,
--VIP1
--VIP1
Rust is corrosion, but all corrosion isn't rust. Non ferrous metals don't rust, they corrode. But anyway.....
Yes I agree...pass on the aluminum sub frames. I really doubt they would be strong enough. As for the alum. LCA's thats up to you. If the guy isnt experienced and hasnt tested them just make sure they will be strong enough too. It all depends on his design.
I have boxed style weld in subs and steel tubular LCA's...works great for me. I have $250 in my set up brand new.
Originally Posted by Zero_FactiX
I found a guy that said he will make me some Aluminum SFC's and Aluminum LCA's for $250. but wouldn't aluminum rust?
Hardly worth the effort in my opinion.
There are many commonly avilabale processes to stop the corrosion of AL when exposed to the elements. Powder coating and anodizing are two that immediately come to mind. Paint also is an effective method of corrosion prevention.
Originally Posted by NOZR1
Rust is oxidation. Aluminum will not rust.
Anyway, this is getting off-topic.
--VIP1
Yes, rust is oxidation. Aluminum will oxidize. It just wont disintegrate like an iron ore derivative. Almost anything will oxidize. Oxidation just means that the object has combined with oxygen.
--VIP1
--VIP1
- The combination of a substance with oxygen.
- A reaction in which the atoms in an element lose electrons and the valence of the element is correspondingly increased.
Corrosion:
- Any of various powdery or scaly reddish-brown or reddish-yellow hydrated ferric oxides formed on iron and iron-containing materials by low-temperature oxidation in the presence of water.
- Any of various metallic coatings, especially oxides, formed by corrosion.
- A stain or coating resembling iron rust.
- Deterioration, as of ability, resulting from inactivity or neglect.
Originally Posted by CANNIBAL
Oxidation:
Corrosion:
Corrosion:
Thanks Levi!
Easy pneumonic for oxidation is OIL, Oxidation Is Loss of electrons.
Cannibal:
Thanks for the post.
I dont want to sound rude...but,I knew that already. I have taken a few years of chemistry and usually scored near the top of the class.
Were you trying to prove or disprove what I said?
It seems like you proved what I said.
I dont mean to sound rude or an a-hole.
Cannibal and Trackbird:
Are you guys moderators? I don't remember. You guys post on here a lot and know what you are talking about.
Sorry to the thread-starter (Zero_FactiX) for the side-track.
--VIP1
--VIP1
