10 Bolt Rear??
10 Bolt Rear??
So I Hear That These 10 Bolt Rear's Are Terrible... So I Look Back there Today To Find That One Bolt Is Already Missing.... I'm Wondering If I Should Be Concerned Or If It'll Last For a While Long Or If I Should Just Get The 12 Bolt And Call It A Day
LS1Tech Administrator
Received 1,795 Likes
You have an auto. You will need to be making a lot more power than you currently are (and racing the car often) to need anything more than a 10-bolt. M6 cars are a different story...these are the ones popping stock rears with stock engines.
As long as you can keep wheel hop away, and you don't let the diff run low on fluid, you'll be hard pressed to break the 10-bolt in an A4 car that's primarily street driven.
What bolt is missing? From the diff cover? Is the cover gasket leaking any fluid?
I Don't See Any Fluid Under There So I Guess I'm In The Clear For Now.
I snapped my rear end last friday night at the track. I'm an M6 tho. I have made this mistake along with many others.... Build your car from BACK TO FRONT. No point in having lots of power if your drivetrain cannot handle it. Go with a 12 bolt!
Sure, it's nice to have a 12-bolt even on an A4 car, but it's certainly not manditory for the auto. I'd just run the stock rear until you break it, which may never happen behind an A4 (even at heads/cam level) if you can keep wheel hop away.
As if the 10 bolt wasn't bad enough, the poor OP got the cost saving 9-bolt. Just messing.
If it's a bolt for the rear cover, i hope it isn't near the 6 o'clock position. At any rate, get a new bolt and drive it in there. If it was me, I'd change the fluid and gasket too while I'm under there.
The 10-bolt can handle it with an A4, for quite a while. I had the same 10-bolt for 4 years with a 1.6 60-foot full weight Trans Am, 3500 stall and drag radials. Rear was still perfect when I sold it. At the same time, I was racing with a bunch of guys that had similarly built A4 cars, all with stock rears and no problems.
Thx for the Help Guys! I'm Going to Be Asking Alot More Questions As I Progress On The TA.
And im gonna agree.
Reason is don't fix nothing till its broke. My buddy is pushing around 550+ in his TA with the stock rear end (his is a M6) but my other friend with a SS (M6 as well) has yet to make a pass at the track with his 10 bolt. Some hold up well others do not. Im gonna say save up for the the new rear end then that way when it breaks you have the funds for a new one. besides if you do break the 10 bolt it only takes a couple hours to fix for the most part and around $50.00 in parts at least it dose for me and my buddy's (we got hook ups).
GL and remember it pays to play!
