Rotating assy oopsie DOHH
Finally started cracking down on my baby motor build. I acquired a set of SRP 138093 .030 over pistons. Link They came out of a friends 383 LT1. I planned on using them in my 355 LT1 build. BUUT I noticed that the wrist pin is much closer to the top of the piston compared to a stock piston. And they are rated for a 6" rod not a 5.7". I plan on buying new rods and using the stock crank. Is there a rod that I could use that would still allow me to use these pistons and the stock crank? Or do I need to start over? Halp!
Rod sounds really long because it is what is needed to run a 383 piston with a 350 stroke.
You think nobody ever ran a couple hundred HP worth of juice through a 6.0" rod 383???
Guys have done 150-175 with amazing reliability on stock shortblocks and a few gamblers have aimed higher, stock shortblocks have been known to survive 250-280 for a while if the owner knows their stuff.
I ran a 100 shot on a bone stock 160k mile motor for 60+ runs. 0-100/130MPH mostly. (even on the bottle it took more than 16secs to get there) Motor's still running like a champ at 190k. Just leaking all over
Thanks for all the help!
I see that CNC Motorsports is having a sale on scat rods. Curious if anyone else has any pros/cons on the idea of running a 6.125" rod on a heads/cam 200 shot 355?
BUMP
BUMP
