What do they weigh
What do they weigh
Sticky isnt working might as well put all the weight in here
10 bolt Stock 4 channel 10bolt wieghed inabout 155lbs dry
12 bolt Moser 12 both with 373 gears and 33 spline axles = 203 lbs
9 inch XXXXX missing 200
MWC 9 inch , Midwest 9 with 35 spline gun drilled/star flange axles and Moser 9 iron
center section spool. 175lbs
fab 9" is 172lbs with 4 channel and iorn center section 31 spline and posi.
fab 9" with Aluminum center section 33 spline gun drilled and spool it wieghs in at 150 lbs
S60 224 dry
Stole this from another thread
s60 weight something like 225 lbs and moser 9 inch weight something like 200 lbs. The stock 10 bolt weighed 150 lbs seems pretty close
Add to it if you know some
Jay
S60 224 dry
Jay
