Starting issuesss
Old 07-04-2010, 01:33 AM
kp483's Avatar
Default Starting issuesss
I started my car this morning and drove it to work then went to start it again after work It, turn the key.. put the clutch in and nothing in the start position. Took the key out and tried again.. Started right up.
Has been hit or miss for the past few days, today in the mcdonalds line shut it off to order(open cutout).. went to start it and it and it began to start and died out, then tried again cranked right up.
Thanks
Old 07-04-2010, 09:35 AM
blade2222's Avatar
check the connections at the battery and the starter, had a bad connection at the starter that did the same to me.
Old 07-04-2010, 11:53 AM
kp483's Avatar
Will do thanks.. Check light hasnt came on but could be because of the tune, Will check it out with a tech2 as well come monday
Old 07-04-2010, 02:33 PM
TImmy_Jones's Avatar
Saw you had a came, whats the idle set at? Is it dying because of the cam?
Old 07-04-2010, 02:46 PM
kp483's Avatar
Cant be the cam.. Idle is around 800. It just started this week.. Maybe even Houston's humidity/rain is playing a role in this
Old 07-14-2010, 04:40 PM
JG25's Avatar
im having the same problem with my camaro also. like you said its a hit or miss.. sometimes is will start sometimes it wont. i cannot figure out what the problem is. turn the key to crank but nothing happens. lights on dash work but just no crank. did you figure out the problem yet?
Old 07-17-2010, 04:55 PM
formulafast's Avatar
you get the problem fixed yet i have the same issues
Old 07-29-2010, 10:47 PM
kp483's Avatar
Sorry I have not... the problem went away on its own.. strange..
