Clutch not Disengaging.....master cylinder pulsating
Old 07-04-2010, 03:25 PM
perezpowerbuilders's Avatar
Default Clutch not Disengaging.....master cylinder pulsating
ok....clutch has been having problems disengaging over the last couple of days....today of all days....the clutch stopped disengaging. I felt and heard a loud pulsating sound coming from the clutch pedal. Right now cant get the transmission to go into any gears.....would this be a sign of slave cylinder failure? already spent a few hrs bleeding the clutch.....no improvement at all. Is it time to drop the transmisson and install a new slave cylinder? ....any ideas or thoughts? thx for your help.
Old 07-04-2010, 04:14 PM
raven154's Avatar
If its pulsating, sounds like a throwout bearing or the clutch.
Old 07-04-2010, 04:24 PM
I was thinking it could be the clutch gone bad...maybe the pressure plate broke...clutch seems to be always engaged not disengaging at all. Guess I should look at getting a new clutch too....Thanks for the input .
Old 07-04-2010, 07:03 PM
Chrismikeb's Avatar
ive been in a similar situation, normal driving i put it in 5th and began to let off the clutch, i hear a loud *** bang the clutch pedal just became free as a bird all kinds of grinding sounds n ****...pull off the road shut it down, and i couldnt push the clutch pedal in AT ALL, turns out the throwout bearing shattered, so might wanna look into that....hope that helps
Old 07-04-2010, 07:14 PM
madmike9396's Avatar
Save up some coin and get a Monster clutch and a Tick master cylinder
Old 07-04-2010, 07:29 PM
yep...I know its going to cost me some coin. Luckily Im doing all the work myself that will save me some money....problem is I need my car running by tuesday morning the clock is ticking....tick..tick....its been so freakn hot and humid today...thank you hurricane alex!!! Thanks for the input.
Old 07-04-2010, 08:00 PM
i got the stage 2 monster 1260 and had it installed for 435 at tick performance but i got the hole package, Tick Master Cylinder slave cylinder throw out bearing pilot bearing and clutch kit i also upgraded to a different flywheel, Check out there packages at tickshift.com
Quick Reply: Clutch not Disengaging.....master cylinder pulsating
